Help finding a front wheel hub
Old 05-23-2007, 10:24 AM
steves65korvette
steves65korvette's Avatar
Default Help finding a front wheel hub
I posted this in the parts wanted/for sale section but have gotten no leads yet. I hope it is ok to post here as well and maybe get more exposure. Does anyone know where I can get a front wheel center hub for a 65? I have checked the vendors web pages along with the catalogs, as well as local parts stores here with no luck. Web searches have been fruitless also. Everyone has the rotors but no hubs. Any help will be appreciated. Thanks, Steve
Old 05-23-2007, 11:43 AM
gldnkngt
gldnkngt's Avatar
Try Brad's Corvette Parts in Ft. Lauderdale. He still has a lot of mid-year parts on hand.
Old 05-23-2007, 12:35 PM
ssgnco
ssgnco's Avatar
Long Island Corvette lists a used hub and a hub/rotor set. They don't have prices with them, which may mean they don't actually have them in stock.
Old 05-23-2007, 12:48 PM
ssgnco
ssgnco's Avatar
You may be out of luck. I found this on the internet on the Herlinger's Corvette site. As he suggests, you may consider replacing the spindle and hub with some newer ones.
Many of the parts on the front suspension such as: hub rotor assemblies, front spindles, spindle arms and brake caliper brackets were discontinued long ago. Midyear (1963-1967) suspension parts in good used condition are almost impossible to find. We are fortunate because if needed a front spindle and hub assembly for a 1965 Corvette can be up dated with a 1969 through 1982 spindle assembly. Chevrolet made so many of the later Corvettes especially 1973-1982 that used front suspension parts are still fairly plentiful and can be found at most Corvette auto wreckers.
Old 05-23-2007, 02:07 PM
C64BOB
C64BOB's Avatar
What's wrong with the hub you have? If the bearing race has pounded itself loose in the hub it can be sleeved.
Old 05-23-2007, 02:13 PM
wombvette
wombvette's Avatar
It is the same hub that is used on some other Chevys of the era except for the drilled holes for the rotor. They are not needed anyway. You may be able to find one in an older junk yard.
Old 05-23-2007, 02:34 PM
mikem350
mikem350's Avatar
Most of the front suspension pieces for disc brake cars interchange from 65-82. I just used a complete 79 set up on my 66.
Try the C3 forum, or any local Vette shop!!!
Old 05-23-2007, 06:07 PM
steves65korvette
First, Thank everyone for all the replies. I had thought about the machine shop route but I really just wanted to replace it. Also, I don't want to replace it with a later model set-up if possible. Seeing as how they seem to be as scarce as hens teeth, it looks like I am going see if I can have it sleeved. Talked to a local machine shop today and they seemed to think they can take care of it. Again, thanks for all the advice. This is a great forum with a lot of great people. Steve
Old 05-24-2007, 08:40 AM
michaeliss
michaeliss's Avatar
In the restoration of my '67, the hub would hold the dust cap on. it would fall off. Investigating this further, the bearing had married it self to the spindle. IT must have heated up and expanded the hub. I could not find a new one anywhere. I ended up buying a a used one from Paragon. It was good.
Old 05-24-2007, 11:46 AM
MikeM
MikeM's Avatar
Received 1,843 Likes on 1,398 Posts
I have found a fair number of hubs (not Corvette, but it doesn't matter) where the bearing seized and spin the race in the hub, making it too large to hold a new race in. I center punched the hub around the race bore in 6-8 places. It swells the metal and it will hold the new race. Sometimes they're wallered out too big to do this.
Of course, I wouldn't expect anyone to repair a CORVETTE this way.
Old 05-24-2007, 08:28 PM
Wilkinshc
Wilkinshc's Avatar
I have a pair if your interested. Shoot me an email or pm and I can send pics if you interested. I bought them from Long Island a year or two ago but decided to go with c3 spindles and hubs. I will sell them for what I bought them for.
Chuck
Old 05-24-2007, 08:56 PM
riogrand
riogrand's Avatar
You might try here as well.
http://www.duntovmotors.com/FrontSuspension.htm
Old 05-26-2007, 01:30 AM
MrTrim
Support Corvetteforum!
MrTrim's Avatar
Steve, If you only need 1 hub try my friend Corvette David @ 310-329-5334 he has all kinds of cool Corvette parts in So Cal. He ships nation wide.
Old 05-26-2007, 06:55 AM
steves65korvette
Thanks to EVERYONE ! I couldn't survive without this forum ! Steve
Old 05-27-2007, 04:53 AM
DansYellow66
DansYellow66's Avatar
Received 2,620 Likes on 1,952 Posts
You might try Bairs. I bought several used suspension parts from them during my rebuild.
Dan
To Help finding a front wheel hub
Quick Reply: Help finding a front wheel hub
