Corvette Forum
Go Back   Corvette Forum > C1 & C2 Corvettes, 1953 - 1967 > C1 & C2 Corvettes
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
C1 & C2 Corvettes
General C1 Corvette & C2 Corvette Discussion, Technical Info, Performance Upgrades, Project Builds, Restorations Sponsored by
Corvette Specialties
of Maryland
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-11-2007, 09:39 AM   #1
Black_Magic
CF Senior Member
CI 2-3-4-5-6-7-9-10-11 Vet
CI 4-5-7-9-10-11 Car Show Winner
1965 Chevrolet Corvette
Black_Magic's Avatar
Default Solenoid for A/C
Those of you who have added A/C know that when the compressor kick in the RPM's drop to almost stall conditions. I did a search and using information from various post I consolidated and took a few pictures. This worked for me as it was a bolt on.
NOTE ** I'm running a Holley 650 Street Avenger carb that already had both holes. Your carb may or may not have these hole and you will need to drill/tap or adjust to your situation.
Parts: There are other combinations but these fit perfect
Holley universal mounting bracket 20-9
GP Sorenson Solenoid 779-1904
click on image for larger view
Then you need to run a wire (12V +) that is spliced into wire that engages compressor to solenoid.
Then a little adjustment (solenoid in/out) to get RPM set correctly.
George
__________________
Click Here for Black_Magic Home Page
'65 Blue/Blue ZZ4-Dual Quads, TKO 5sp, PS, PB A/C, Tilt, Sidepipes, Torque Thrust II (17*7) (DRIVER)
Black_Magic is offline   Reply With Quote
Old 05-11-2007, 10:54 AM   #2
Kensmith
CF Senior Member
Support Corvetteforum!
Kensmith's Avatar
Edelbrock also sells them through Summit Racing for standard carbs but unk if it will fit Holley? They call them Idle Compensators. $89.00 at Summit. Has a little different mounting bracket. Also, these must have a full 12 volts to work so if your alternator is only putting out 8 to 10 volts at idle, it won't work. Trust me, I know. I sent one back to find out the hard way and ended up swapping to a smaller alternator pulley to increase voltage at idle. (on my 32 coupe with 1 wire 100amp alt).
Kensmith is offline   Reply With Quote
Old 05-11-2007, 11:28 AM   #3
wmf62
CF Senior Member
St. Jude Donor '07
wmf62's Avatar
same thing for FI (kinda sorta):
Bill
wmf62 is offline   Reply With Quote
Old 05-11-2007, 11:34 AM   #4
67vetteal
CF Senior Member
67vetteal's Avatar
Quote:
Originally Posted by Kensmith View Post
Edelbrock also sells them through Summit Racing for standard carbs but unk if it will fit Holley? They call them Idle Compensator's. $89.00 at Summit. Has a little different mounting bracket. Also, these must have a full 12 volts to work so if your alternator is only putting out 8 to 10 volts at idle, it won't work. Trust me, I know. I sent one back to find out the hard way and ended up swapping to a smaller alternator pulley to increase voltage at idle. (on my 32 coupe with 1 wire 100amp alt).
Ken, To avoid this situation why not tap into a Battery direct circuit? Either the starter or a connector at the Pos. Terminal of the battery. A 15Amp Fuse should do the trick without too much Amperage. Al W.
67vetteal is offline   Reply With Quote
Old 05-11-2007, 11:39 AM   #5
67vetteal
CF Senior Member
67vetteal's Avatar
George, Thanks for this posting. It will be a great help for me and anyone with an A/C car. Stock or Non-stock. Al W.
Old 05-11-2007, 11:45 AM   #6
JohnZ
CF Senior Member
Quote:
I did the same thing when I built my Grand Sport - worked great! BTW, the white nylon sleeve in the rubber bushing on the carb lever should have the flange on the inboard (carb) side; it's there to prevent the cotter pin from tearing up the rubber bushing.
JohnZ is offline   Reply With Quote
Old 05-11-2007, 05:00 PM   #7
Black_Magic
CF Senior Member
Quote:
Thanks John I knew that but somehow installed A$$ backwards
FIXED
George
Old 05-11-2007, 05:06 PM   #8
wmf62
CF Senior Member
St. Jude Donor '07
wmf62's Avatar
Quote:
the solenoid should actuate with the compressor clutch, not be energized all the time....
Bill
Old 05-11-2007, 05:08 PM   #9
wmf62
CF Senior Member
St. Jude Donor '07
wmf62's Avatar
1-wire alternators are notorious for not putting out at idle, and therefore are not a good application for a street car....
Bill
Old 05-11-2007, 08:54 PM   #10
Kensmith
CF Senior Member
Kensmith's Avatar
Was easier to swap to the smaller pulley and get 12 volts at idle. Had the pulley already (well, have a few anyway).
Old 05-11-2007, 08:56 PM   #11
Kensmith
CF Senior Member
Kensmith's Avatar
Quote:
Bill
Yes, I will never have one again. Clean looking though. Lessons we learn the hard expensive way!
Old 05-11-2007, 08:58 PM   #12
Kensmith
CF Senior Member
Kensmith's Avatar
Bill
YEP!
Old 05-11-2007, 09:28 PM   #13
67-427ci
CF Senior Member
67-427ci's Avatar
Has anyone seen this done on a Big Block Tri-Power car? I purchased the solenoid, a generic bracket and ran the wire when I installed my A/C (2 summers ago), but never figured a good way to mount it. If anyone has a picture of a way to mount the solenoid, I would love to see it.
Thanks, Roy
67-427ci is offline   Reply With Quote
Old 05-11-2007, 09:49 PM   #14
hpexpatriot
CF Senior Member
Quote:
Thanks, Roy
I did it with a piece of angle iron from Home Depot. Lots of fitting cutting fitting and more cutting but it works. Mounts to the rear drivers side stud on the center carb. This is one of those jobs that takes time and patience...lots of both are reqired. Total material investment for the bracket is about $5.00
hpexpatriot is offline   Reply With Quote
Old 05-11-2007, 10:18 PM   #15
67-427ci
CF Senior Member
67-427ci's Avatar
Quote:
Any chance you could post a picture of your work?
Thanks, Roy
Old 05-11-2007, 10:22 PM   #16
magicv8
Long Hauler X 7
1969 Pontiac GTO
magicv8's Avatar
Location: Going too fast over the hill. Lots of miles. Lots of smiles. I drive a Corvette
I made my bracket from aluminum, and got a $16 solenoid from a local aouto parts store. Just hook the 12volt wire to the A-C compressor and the idle never drops.
magicv8 is online now   Reply With Quote
Old 05-12-2007, 10:16 AM   #17
hpexpatriot
CF Senior Member
Thanks, Roy
I have never posted a picture on any board. Just had to many hassels trying. Also lazy I guess, I know I should learn but too many other things to do, like making solenoid brackets. If someone wants to post the PICS for me I can forward them to whomever volunteers to do the post. I have some high resoultion pictures that can be zoomed into for excellent detail.
Old 05-13-2007, 09:06 PM   #18
67-427ci
CF Senior Member
67-427ci's Avatar
Default 3x2 Carb A/C Solenoid
I am posting these pictures for fellow forum member hpexpatriot (thanks Ray).
I was having a hard time visualizing how to install a solenoid for my 3x2 setup. Looks like a very clean job.
Roy
Old 05-14-2007, 11:46 AM   #19
hpexpatriot
CF Senior Member
Glad to help. I hope some of the other guys find this useful. As you can see it is a little tight down by the accelerator pump and the fuel line into the center carb but it works so that is the real measure of the job.
For those not so close to our conversations Roy, this bracket was made starting with a simple piece of angle iron I bought at the local Home Depot. It takes some patience, a bench grinder and a Dremmel along with one of those air powered cuttoff tools and a few grinding stones for the air tool. The brackket is not something you can "rip off" in an hour or less: be real careful to get the overall shape correct before drilling any holes. Once a hole is in the wrong place it is suddenly and unchangeably time to ....."Start all over again". Ask me how I know that!!!!!!!!
Old 05-14-2007, 12:02 PM   #20
ro.co3
CF Senior Member
ro.co3's Avatar
Would anybody happen to have a pic of a setup with an edelbrock. I'd like to do this to mine but cant figure out how to do the bracket. I 'd use the one from edelbrock but the solenoid at the parts house is only $20 so to pay an extra $69 for the bracket is lot of tooling. Thanks for any help.
ro.co3 is offline   Reply With Quote
Reload this Page Solenoid for A/C
Tags
1904, 7791904, compensator, edelbrock, gp, idle, solenoid, sorenson
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
A/c Wiring On A 69 Vette whiteflame C3 Tech/Performance 11 04-12-2005 02:20 PM
my 350 secrets revealed.. but i have a question Corz Engine Mods 20 07-07-2003 01:53 AM
Vacuum solenoid for wipers TXShark C3 Tech/Performance 14 12-08-2002 08:57 PM
SEALING UNDERDASH A/C DUCTS...AND THAT "TRAP DOOR" TOO ? OkeeGuy C3 Tech/Performance 25 06-11-2002 10:22 PM
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive - Top
Powered by vBulletin
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
