Go Back   Corvette Forum > C1 & C2 Corvettes, 1953 - 1967 > C1 & C2 Corvettes
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C1 & C2 Corvettes
General C1 Corvette & C2 Corvette Discussion, Technical Info, Performance Upgrades, Project Builds, Restorations Sponsored by
Flaming River
Industries
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-28-2007, 03:10 PM   #1
Dean757
CF Senior Member
Support Corvetteforum!
Dean757's Avatar
Default Edlebrock 8867 carbs cfm?
THe manifold is an edlebrock c26 with 2 carbs. They are numbered edlebrock 8867. They are on a 39700010 block. Any guess as to the carbs cfm rating? Thanks DEan
Dean757 is offline   Reply With Quote
Old 03-28-2007, 09:09 PM   #2
Dean757
CF Senior Member
Dean757's Avatar
Default 2 ladies did not know the carbs cfm either
helpers magicv8 says the carbs are 500 cfm, some guys were guessing the other size, One said 38's, the other said 4gs.
Old 03-29-2007, 09:39 AM   #3
magicv8
9 Hot Rod Power Tours
magicv8's Avatar
Have you tried asking Edelbrock? I keep some data for carter AFBs, but not for aftermarket carbs, since the vendors are still out there.
magicv8 is offline   Reply With Quote
Old 03-29-2007, 10:01 AM   #4
Dean757
CF Senior Member
Dean757's Avatar
Default Thanks
Thanks, They are set up so just one or both can work depending on linkage setting. It runs fine on one , and I have not had time to try it with 2. Dean
Old 03-29-2007, 10:50 PM   #5
magicv8
magicv8's Avatar
From the Mustang forum:
"The Edelbrock on my car now has 1407 2111 stamped on the front driver's side where it bolts to the manifold. It has a 8867 on top.
1407 is a manual choke 750 cfm"
IMO one 750 cfm is too big for a 327. If yours also has the 1407 on it, and the above info is correct, one carb is enough for an sb.
Old 03-29-2007, 11:15 PM   #6
Dean757
CF Senior Member
Dean757's Avatar
Thanks magic , I will look. 1 carb does run fine and I think the 2 are more for show than go.
Old 03-30-2007, 10:28 AM   #7
magicv8
magicv8's Avatar
I am guessing that 8867 is the air horn part number. If your carb has 1406 stamped on it, it is a 600cfm according to the Mustang forum post.
Old 03-30-2007, 10:56 AM   #8
Dean757
CF Senior Member
Dean757's Avatar
Default 1404
Thanks just lo0ked
the front carb 1404 0813, assume rear is the same. Perhaps they are 450's and The linkage should be adjusted to run both and it will really wake up. It runs fine now and prev owner said he adjusted for gas mpg. Dean
Old 03-30-2007, 11:11 AM   #9
magicv8
magicv8's Avatar
500 cfm according to the one for sale on ebay, which indicates the second one should be needed when 355cu.in./1728cu.in./cu.ft. are turning 4866 rpm with a 4 cycle engine (every other down stroke is intake)??
Essentially, if the secondaries of both carbs have a counterweighted air valve above the venturis, the engine should run on the primaries (of both carbs) and part of the secondaries as it approaches redline at WOT. The air valves should regulate the secondary openings according to manifold flow.
PS what king of rad is that, and does the car have a hood scoop? I can't tell from the pic.
Reload this Page Edlebrock 8867 carbs cfm?
Tags
1404, 1406, 1407, 8867, accessories, air, carb, carburator, carburetor, carter, cfm, corvette, edelbrock, edlebrock, number, part, zr1
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
