Body off 61 Rod project
#81
Hope you can get on track soon. I will look forward to reading your new post. I just started putting together a Billy frame. Did you have any isues with the cross member or fitting the diff spacers?
#82
Good to see you post a reply. I'm also on the "slow boat to China" on our 58 rebuild. We have had it for almost 30 years, was a basket case when purchased, and always the "next" project. I purchased a Corvette Correction frame 3 years ago but am just now really working on it. Stay with it and I look forward to more progress posts.
Ricky
Ricky
#83
If you have any problems at all with the Corvette Correction parts, give Billy a call. He'll make it right.
#84
Not sure if this will work:
http://ls1tech.com/forums/conversion...tall-body.html
I believe Holley offers a Corvette style bracket using the F-body balancer depth.
I like the the looks of the Speedway alternator bracket. And if I use that I won't have to mess with the Camaro power steering pump. Looks like once my project is complete I'll have a stock and new early C5 alternator bracket with fabricated spacers for sale....
#85
Still lurking...how's it going ?
Stan
Stan
#87
Stan, Thanks for your patience! Been real slow going here. Lots of excuses, just no good ones! Here's a recent pic of the '61 getting some fresh air after being cooped up in the garage for a few years....
You're driving yours already no?
#88
Allrightey then glad to see it moving again...thats too nice a car to not get finished some day. Keep the progress posted...looking forward to more pics.
Mine has 85 miles on it...but I built a new Dart block...with Tony Mammo
massaged intake and AFR heads and his custom roller billet cam that goes in the car after Christmas.
Hopefully that will be the last major change to the car .
In the mean time I picked upa '69 GTO and a '67 Camaro project...like I have time for them..lol!
#89
Long time but I'm back!
Been more than a couple years since I've posted progress pics of my 61 RestoMod project. Today I cut a hole in the firewall to start mock-up of the Ididit column and ball mount. Next will be measure and cut the shaft to connect to the rack. It'll be nice to actually steer this thing instead of muscleing the tires in position as I roll it around. Once everything is mocked up, I'll pull it all out and make a steel firewall reinforcement plate. I'll be running a hydraulic clutch and don't want a firewall failure from the pedal pressure. Lots more work to go but I'll try to make steady progress as I am finally retired. The C1 competes for time with my other projects though and I am currently in deep on a 66 Suburban body being grafted onto a 2002 4WD Tahoe floorpan, firewall, chassis and drivetrain. TaBurban.
#90
Sorry about not replying sooner, I've been sick, but am much better...hopefully for a loong time. Keep up the progress reports...and pics. Till next time, all the best, Stan..
