365hp Alternator Pulley
Can someone explain why the 365hp motor (and other larger hp engines) had a wider machined pulley on the alternator versus what came with the smaller hp engines?
Received 6,943 Likes
2015 C2 of Year Finalist
The combination of the deep grove pulleys and what grove the alt belt runs on
Received 3,048 Likes
C1 of Year Finalist (performance mods) 2019
The alt belt runs on the outer grove of the double grove pulley
Received 1,919 Likes
The larger diameter allows the alternator to turn more slowly, avoiding over-speeding it.
The deep groove helps prevent throwing the belt at high rpm or when quickly changing speed.
The thickness allows it to align with the outer belt, as the SHP engines came with the inner belt that used the idler pulley.
65 Pro Vette (11-19-2019)
Received 2,339 Likes
For whatever reason the 340 and 365 hp alternators pulley groove is spaced out away from the alternator (possibly, as mentioned, to provide alignment with room for the deep grooves in the crank and water pump pulleys).
In a pinch a dual groove alternator pulley aligns the belt in the outer groove.
Corvette Central shows this alternator pulley as correct for 1965 350-365 h.p. and A/C. but I doubt that it was the case OEM but is in fact a catch-all pulley. The 350 and 365 should be different since one used and idler (tensioner) pulley and one did not, PS was available with 350 and not with the 365. A/C and PS were available together with the 350. There were a lot of different crank, WP, PS, A/C and alternator pulley combinations on C2s
https://www.corvettecentral.com/c3-6...ey%26count%3d9
More pulley info in this thread.
https://www.corvetteforum.com/forums...ng-belt-3.html
Received 1,974 Likes
IIRC the Delco specified max rotor speed for their alternators is 18,000 RPM. So in order to avoid exceeding this speed with the high redline mechanical lifter engines the pulley effective diameter had to be larger to slow it down, and given the higher idle speed of mechanical lifter engines, it provided sufficient speed/amps at idle speed.
Given the relatively low volume of these SHP/FI engines it was probably cheaper to machine these pulleys than tool up to make the two piece stamped pulley used on most engines, so what you got was something that was a bit heavy, but bulletproof.
Duke
Duke
Duke
Duke
Hi Duke,
I found your post from late last year on alternator pulleys. You may recall, you helped me tune / time my 65 L76 last month and it runs great now. Thanks again!
I am now looking to correct a few incorrect parts on the car and am working on restoring the correct 37 amp 1100693 alternator for the car . Do you know the part number for the correct 3 5/8 deep grove pulley? Is it 3829387 AI by chance? Is there a pn for the fan?
Chuck
Chuck
