Alternator bracket for headers...
Old 03-08-2007, 07:08 PM
Dicecal
Dicecal's Avatar
Default Alternator bracket for headers...
Anyone know where I could find a quality alternater bracket for use with headers? I need one for a 65, passenger side with a small block. I'm going with the hedman headers, but their brackets look pretty cheap. I've had similar brackets before that always cracked. Thanks!
Old 03-08-2007, 08:16 PM
knight37128
knight37128's Avatar
Something like this?
There are many choices....................
http://store.summitracing.com/egnsea...115+4294840116
Old 03-08-2007, 10:24 PM
cookie_monster
cookie_monster's Avatar
Hedman part # 20020 is the thickest one I've seen. There are twice the thickness of the cheap chrome ones that all speed shops carries. Black paint is poor though.
http://store.summitracing.com/partde...0&autoview=sku
Old 03-08-2007, 10:25 PM
Dicecal
Dicecal's Avatar
Thanks!
Old 03-09-2007, 12:42 AM
r66stingray
r66stingray's Avatar
I went the other direction. I took a set of headers off a '66 small block l-79 and found myself looking for the correct bracket to use in conjuntion with a set of stock exhaust manifolds. I removed an aftermarket alternator bracket with a part number 3951337 with the headers, which is a heavy metal bracket. It seems this part number is common for '72-'82 corvettes. After putting everything back together with the correct bracket the alternator which is not original, fit perfectly and needed no change in even the belt size. I suspect the bracket would work in your instance if the '65 are close to the '66. Not chrome, not polished but pretty heavy duty. If you would like a picture let me know.
Steve
Old 03-09-2007, 12:51 AM
AZDoug
AZDoug's Avatar
Received 1,478 Likes on 905 Posts
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
That looks like the same bracket that I have and it has worked for almost 30 years.
It can be beefed up with a few triangular gussets and a welder, also, it you want it more rigid.
Doug
Old 03-09-2007, 05:55 AM
aworks
aworks's Avatar
Steve
Yes this 74 vette bracket works perfect. But only if you have later heads with assy. holes.
Old 03-09-2007, 07:28 AM
wmf62
wmf62's Avatar
St. Jude Donor '07
i guess i'm still a cheerleader for Alan Grove. call and ask Greg what they have.
Bill
Old 03-09-2007, 09:17 AM
Dicecal
Dicecal's Avatar
Bill
Thanks, found his web site.
Old 03-09-2007, 10:29 PM
cookie_monster
Doug
Hey Doug,
You're a genius . Why didn't Hedman or Hooker think of your triangular gusset idea?
If anyone knows of a source for a "heavy duty" stainless steel bracket, please holler. I realize I can have one made, but I'm sure it will be too costly.
To Alternator bracket for headers...
Quick Reply: Alternator bracket for headers...
