Factory Cam Specs List- Small Block
Here is a practical application for the use of different rockers on
a 327/350hp L-79.
You are surfing Ebay and notice a set of Vortec L31 #885 heads
with a Buy it Now price of $300.00 complete with valves, rockers,
etc. .....
You buy the heads and order a set of 1.7 ratio rockers... you leave
your L-79 cam intact... but instead of giving you .447/.447 lift...
you are now getting .506/.506 lift... making the most of your head
flow while not digging into the block. L31's go for $300 to $350 a
pair pretty routinely.
If you wanted to to step up a little over the L31's... you could
order the 185cc Bowtie Vortecs for $554 a pair bare from GM Performance Parts Direct.... or the Dart IE Platinums 200cc port for $660.00 a pair bare from Competition Products.... and use the same
rocker ratio trick with your stock L-79 cam.
Intake flow for 492's with stock 1.5's
198cfm at .400 lift
Intake for L31's with 1.7 rockers
239cfm at .500 lift
Intake for Bowite Vortec 185cc with 1.7's
251cfm at .500 lift
Intake for Dart IE Platinum 200cc with 1.7's
274cfm at .500 lift
all figures using the stock L-79 cam...
a 327/350hp L-79.
etc. .....
198cfm at .400 lift
239cfm at .500 lift
251cfm at .500 lift
274cfm at .500 lift
AFR and Dart heads have raised rails. In other words where the valve cover bolts on they are .5 higher than stock GM heads. Thats why roller rockers will fit under stock valve covers when using aftermarket heads. Most will not clear with stock heads. Sometimes double gaskets work or just buy spacers.
Mr. Gasket has special thick valve cover gaskets to help in this area..
B&B Fabrication makes aluminum spacers...but they are $100.00..
Im a big fan of the finned aluminum Corvette valve covers myself...
I just don't really want to change them.
"There is little dispute that cylinder head airflow equals power; we dare say the relationship has been fairly well established. If you are doing everything right to make the most of a set of cylinder heads from a given engine combination, each cfm of intake port airflow is enough to make just over 2 hp in a V-8 engine. If cylinder head airflow isn’t up to the task, no amount of cam or carb is going to coax big power from the engine."
- Steve Dulcich
Editor
Engine Masters Magazine
- Steve Dulcich
Editor
From Chevy Power 5th Edition
#3965754 Mechanical 324in/324ex dur 503in/508ex lift w/1.5 rockers
#366293 "Mushroom" type Cam 325in/335ex dur 560in/575ex lift 117 lsa
the "140" cam 316in/323ex dur 481in/486ex lift .... lsa 108
