Need help decoding engine numbers please
Old 11-15-2006, 09:29 PM
malo68
malo68's Avatar
Default Need help decoding engine numbers please
Hi, I just purchased a 327 engine and the owner didn't know what it was from but I believe it may be from a 66 'vette. Here are the stamping numbers:
Rear engine block (near bellhousing): 3858174
Pad in front of passenger head: FO7II2AS
Heads, under valve cover: 3890462 & F276 & GM15
I would GREATLY appreciate anything you can contribute to helping me decode this engine. I have my fingers crossed that it's something I can use for my first rebuild. Thanks in advance! Malo
Old 11-15-2006, 09:53 PM
63C2splitter
CF Senile Member
Support Corvetteforum!
63C2splitter's Avatar
St. Jude Donor '08
Here is a site that may help.
Dave
http://www.nastyz28.com/sbchevy/sblock.html
Old 11-15-2006, 10:51 PM
Sky65
Sky65's Avatar
St. Jude Donor '05, '09, '15
I am not real good with this numbers stuff but this what it looks like to me.
3858174....327...64-67
3890462....66-67...302/327/350..Camel hump,no accessory holes,64cc chamber
F276 I think is June 27 1966
Old 11-16-2006, 01:34 PM
JohnZ
JohnZ's Avatar
Received 1,857 Likes on 1,100 Posts
Check this stamp again- there should only be two characters after the "F07II" (not three), and both should be letters.
Old 11-16-2006, 11:18 PM
malo68
malo68's Avatar
Here is a tracing from the pad stamping:
Looks to me like its FO71I2AS?
Old 11-17-2006, 06:09 AM
tentuna
tentuna's Avatar
174 casting pegs it to a late 66, don't know about the AS suffix, but the F tells you it was assembled in Flint where all Vette motors were put together.
Old 11-17-2006, 07:20 AM
knight37128
knight37128's Avatar
F = Flint
07 = July
1I = the 11th day
2AS = ???? As John stated there should only be 2 characters not 3.
Old 11-17-2006, 08:01 AM
Don SSDD
Don SSDD's Avatar
FYI, it would not be a Corvette engine with an AS- according to Noland, all 66 327's started with a H or a K, not an A. Most had 461 heads, but 462's showed up late in the production year.
The extra digit makes it a plant stamping error or a restamp error maybe? If the engiine looks like it is original, not decked or bored, it may have been a GM production error.
Don
Old 11-17-2006, 08:46 AM
knight37128
Don
The tool that GM used to "stamp" only held 7 characters or numbers.
Old 11-17-2006, 09:23 AM
hope2
hope2's Avatar
you might want to look at the casting date
Old 11-17-2006, 10:37 AM
JohnZ
JohnZ's Avatar
The only 60's Flint engines I've seen with odd 3-digit suffixes were marine engines (Mercury Marine, Crusader, etc.); that's probably where that one began its life. With a very few rare exceptions, there were no 3-digit suffixes until 1970.
Old 04-01-2010, 03:22 AM
innermelbguy
innermelbguy's Avatar
Hi,i' m lost!
I have a 63 vette(NOM)
My engine number reads 12118112F0206SB
I'm from downunder(Melbourne Australia)and ,after all my research, can't work out what this engine is!!!!!!!
Can you please help?
Regards
John
Old 04-01-2010, 02:41 PM
JohnZ
JohnZ's Avatar
Originally Posted by innermelbguy
Hi,i' m lost!
Regards
John
The "SB" suffix was used on '62-'64 327/300hp in full-size cars; the VIN derivative stamping on that one says it's from a '62. What's the block casting number (U.S. driver's side rear flange) and the casting date (about 5" toward the U.S. passenger side from the distributor)?
Old 04-01-2010, 05:45 PM
innermelbguy
Default Engine number.
Thanks for your response!
This is all the information i have at the moment,i dont have the car yet
as it is just about to be loaded on to a container for shipping to Melbourne,Australia.
I only have photos of engine,not sure if this helps.
Old 04-03-2014, 06:34 PM
vettestingray
3rd Gear
vettestingray's Avatar
Hello,
Where can I find engine ID number for corvette stingray 2014?
Thanks all
Old 04-03-2014, 06:47 PM
AZDoug
AZDoug's Avatar
Received 1,478 Likes on 905 Posts
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
Originally Posted by vettestingray
Hello,
Thanks all
Probably in the C7 section.
Doug
Old 04-03-2014, 09:23 PM
emccomas
emccomas's Avatar
Received 1,283 Likes on 732 Posts
Pretty unusual to find a 62-64 low hp (250 / 300 hp) engine in a passenger car with a VIN derivative on it.
I recently helped a friend sell a 64 Impala with a 327 / 250 hp engine, full option car (S suffix code). The pad did not have a VIN derivative.
Perhaps this varied from assembly plant to assembly plant as the VIN derivatives were phased in throughout the 60s.
To Need help decoding engine numbers please
Old 04-03-2014, 09:25 PM
emccomas
emccomas's Avatar
Need a picture of this engine pad. The image of the pencil tracing is not showing up.
Old 04-03-2014, 09:28 PM
62Jeff
62Jeff's Avatar
His post is 7.5 years old
Old 04-03-2014, 09:34 PM
W Guy
W Guy's Avatar
The full size Chevy assembly plants were directed to stamp the VIN derivitive on the blocks of 300hp and above. The directive began with the '62 model year.
Verne
Quick Reply: Need help decoding engine numbers please
