C2 Fuelie won't start??
Old 09-25-2006, 03:56 PM
mts7900
mts7900's Avatar
Default C2 Fuelie won't start??
My '64 327FI won't start. It kick's over and runs for about 5 seconds and shuts down. It seems to be fuel starved. I've checked the pump drive cable, and for ruptured control and enrichment diaphrams.
Can it be a defective enrichment solenoid? But doesn't that work just during cranking/initial start-up?
Any helpfull suggestions?
Thanks,
Matt
Old 09-25-2006, 04:16 PM
Chuck Gongloff
Support Corvetteforum!
Chuck Gongloff's Avatar
Check to see if you have spark to the plugs first.
Then, take off one of the lines to a nozzle. Have somebody crank the car. See if gas is squirting out.
If not, I'd check to see if the drive cable has one or both of the square ends rounded off, not turning the pump. I've had that happen a time or two.
Chuck
Old 09-25-2006, 05:28 PM
wmf62
wmf62's Avatar
St. Jude Donor '07
yep, injection pump drive cables do break/malfunction at the most inconvenient times. ALWAYS carry a spare....
Bill
Old 09-25-2006, 06:04 PM
MikeM
MikeM's Avatar
Received 1,843 Likes on 1,398 Posts
Thanks,
Matt
I agree with Chuck and Bill. Pump cable may be rounded off. Your engine is probably starting and running from the squirt of fuel the fuel enrichment solenoid is putting in there when you engage the starter. When that's gone, the engine dies and gets another shot when you engage the starter again.
A question though. How did it run before this happened?
I also agree it'd be a good idea to check for spark.
Old 09-25-2006, 07:15 PM
mts7900
mts7900's Avatar
Thanks for all the help guys. I've got spark and fuel from the primary pump. But it does look as though the pump end of the drive cable is a bit rounded. The distributor end looks sharper. I'll replace it anyway and go from there.
Matt
Old 09-26-2006, 10:36 PM
pat ladner
pat ladner's Avatar
Matt,
If these suggestions fail, call Jerry Bramlett @ 251-478-4003. He is the best around and is easy to work with.
To C2 Fuelie won't start??
Quick Reply: C2 Fuelie won't start??
