How to install outside mirror glass?
So I ordered the dated glass from Paragon, can someone detail the steps to install the glass in my existing mirror?
I can see a steel ring just around the glass, is this the starting point?
Thanks guys
Thanks guys
The glass is retained by the snap ring. The glass is held against the snap ring by 3 springs behind it. Put the mirror on a folded towel, press the glass into the head and remove the snap ring with an awl.
I'm sorry, but what year mirror is this? I know the 67 mirror is held in with silicone adhesive. soak it in lacquer thinner and the silicone will allow the glass to be removed. Or was it mineral spirits? memory is failing. I think I searched the ncrs site..
I've found it best to cut a circle about 1" smaller diameter than the mirror out of 3/8" or 1/2" plywood, pad this with 2-3 layers of towel and press against the mirror in order to compress the 3 springs behind the mirror enough to remove the snap ring holding the mirror in place. Holding the mirror in slightly, you can remove the ring and the mirror will come right out. Installation is the reverse of these steps.
The reason I use the plywood is that it spreads out any pressure against the mirror to the full face of the mirror. I've seen mirrors broken (snap in the center) when pressing a finger against the mirror to compress the springs. Not saying it can't be done, I just don't choose to risk breakage of the old or new mirror unnecessarily. Just my way of doing it!!
Ron
Ron
Received 1,858 Likes
Originally Posted by JohnZ
That's true for most C3 mirrors, but the '67 mirror glass has three springs behind it and is retained by a stainless ring.
