do I need a puller to remove the steering wheel?
Old 07-17-2006, 01:31 PM
theybot
theybot's Avatar
Default do I need a puller to remove the steering wheel?
Got the center 3/4 inch bolt off but the wheel is still tight. Do I need a gear puller to get it off?
Old 07-17-2006, 01:33 PM
Silver '65
Silver '65's Avatar
I always have needed one.
Old 07-17-2006, 01:34 PM
JohnZ
Support Corvetteforum!
JohnZ's Avatar
Received 1,856 Likes on 1,099 Posts
A gear puller will chew up the edge of the hub - you can get a steering wheel puller for less than ten bucks at any auto parts store, or they'll usually rent you one free.
Old 07-17-2006, 06:32 PM
63C2splitter
CF Senile Member
63C2splitter's Avatar
St. Jude Donor '08
They are fairly inexpensive, and you definately don't want to try to pull it without a puller - could break the wheel.
Dave
http://www.autozone.com/in_our_store...ring_wheel.htm
Old 07-17-2006, 08:16 PM
Hitch
Hitch's Avatar
Why do you need a steering wheel puller to remove the steering wheel? It's only held on by 5 or 6 small phillips screws. Now if you are removing the hub yes you need a puller.. However why are you pulling the hub???? Dave
Old 07-18-2006, 12:22 PM
63Corvette
63Corvette's Avatar
My WHEEL is held on with small screws?
Old 07-18-2006, 12:37 PM
kenmo
kenmo's Avatar
I've removed mine a few times... I would strongly recommend a wheel puller...
Old 07-18-2006, 01:06 PM
Paul L
Paul L's Avatar
Phillips-head screws hold the wheel onto the hub. That's all. If you wish to remove the hub then you will need a puller.
Old 07-18-2006, 01:19 PM
ctjackster
ctjackster's Avatar
I am fairly confident the original poster can see the screws holding the wheel to the hub, since he has the horn button off - the fact that he took the big nut off tells me he is after the hub coming off. But what the heck, let him clarify for us . . . .
Old 07-18-2006, 01:28 PM
MikeM
MikeM's Avatar
Received 1,843 Likes on 1,398 Posts
If you don't want to buy a puller, put your knee under one spoke and put pressure against the SPOKE. Grab the other SPOKE 180* off and pull up on it while you bang the bottom side of the SPOKE with a hard plastic mallet.
Doesn't always work but usually. DON'T pull on the RIM of the wheel.
Old 07-18-2006, 01:47 PM
Plasticman
Plasticman's Avatar
Buy / Rent / Make a steering wheel puller. Easy to take off the hub with it. Frustration without it.
Besides, you will probably be in the column / turn signal area several times! Nature of the beast.
Would also help if you filled in your "Profile" area, and told us which Vette you are working on.
Plasticman
Old 07-18-2006, 02:24 PM
Hitch
Hitch's Avatar
oKAY Jack never assume.. You know what happens then...
Old 07-18-2006, 03:07 PM
joec
joec's Avatar
Default Yupper!!!
Tony Randall (Felix, circa early 70's) you make an A$$ out of U and ME... Great quote and great show...
Old 07-18-2006, 03:20 PM
Vette66AirCoupe
Vette66AirCoupe's Avatar
If he's got a C1 he won't be taking the wheel off by removing screws. Is there a way to tell what generation is being referenced here?
Old 07-18-2006, 03:40 PM
65 Hardnoks
65 Hardnoks's Avatar
I use a harmonic balancer puller. No damage to the hub.
BTW, anyone see The Gumball Rally? I instantly thought of that movie when I saw this thread.
Old 07-18-2006, 05:06 PM
ctjackster
ctjackster's Avatar
my deep research tells me he has a 63 . . .
I learned the ***-U-me lesson the traditonal way - from a hard-nosed coach in 9th grade, in an after game team meeting where he was berating some player for his answer that included "well, I assumed Jack would blah blah blah with the ball". That triggered the ol "When you assume you make an *** out of . . . ." line!
Today, I probably use more of the lessons learned from that one coach (he was just right for that time in our lives) than all of what I learned in High School . . . which brings to mind another line: "when I look back on all the crap I learned in high school, . . . ."
Old 07-18-2006, 05:30 PM
SilverC1
SilverC1's Avatar
Ah, the wisdom of high school football coaches. Some of the gems I heard along the way were:
- You may be little, but you're slow!
- (while watching game film of someone blocking me) - You're moving backwards so fast it's like you're on roller skates!
- (when someone ran around my end - I played OLB on defense) - Oh no! It's Katy bar the door time!
- (to encourage the O-line) Root, hog, or die!
- (While the coach was literally riding on the back of a guy whose last name was Mann, while he was doing "bear crawls" on all fours, during two-a-day August practices) - I want you to get so low you're eating dirt! You're a mole! You're a mole, Mann! (Henceforth Mann was always called "Mole-Man")
Then there was the coaching technique where our coach taught our field goal kicker to concentrate prior to the snap of the ball, by standing next to him with a brand new 16" "Clincher" softball (familiar to Chicago area folks), wrapped in a towel, that the coach swung like a club against the kicker's helmet. "Concentrate! (Thwap!) Concentrate! (Bonk!) Concentrate! (Blam!)"
(Coaches used to get away with a little more abuse back in the early 70's, compared to now.)
Old 07-18-2006, 07:23 PM
theybot
theybot's Avatar
Trying to get to the blinker mechanism. They don't seem to cancel any more.
Toby
Old 07-18-2006, 07:27 PM
theybot
theybot's Avatar
By the way its a 63 Split.
I haven't got around to filling in the profile. Joined the forum before I bought the car.
Sorry. But I will do it soon.
To do I need a puller to remove the steering wheel?
Quick Reply: do I need a puller to remove the steering wheel?
