Underbody fiberglass question
I have a couple of places on the under body that has some fiberglass damage. None of them big about the size of a silver dollar. How can I repair and make it look right? Mainly color. HELP
Hope their is someone that can help
Fiberglass pigment
It's pretty simple, you just add color pigment to your resin..It is sold at most, if not all fiberglass supply places like boat supply shops and TAP Plastic sotres etc, you just need a drop off of a toothpick to color a small amount of resin.
You may already know how to dish grind out the damaged area and lay in some fiberglass mat and resin. When dry, sand to smooth and match surrounding area.
