Zollner Pistons would you use?
Old 11-04-2005, 05:17 PM
ckulchar
ckulchar's Avatar
Default Zollner Pistons would you use?
Has anyone used Zollner pistons in a 1965 396/425 hp motor? Just looking to rebuild the motor to stock specs nothing radical. What would the Zoller part number be?
Charley
Old 11-04-2005, 07:23 PM
bigcypress
bigcypress's Avatar
fred zollner used to own the fort wayne [now detroit] pistons is there a correlation?
Old 11-04-2005, 09:39 PM
SWCDuke
SWCDuke's Avatar
Received 1,974 Likes on 1,188 Posts
Charley
If that's your objective why not use the Speed Pro OE replacement forged pistons?
Duke
Old 11-05-2005, 07:53 AM
ckulchar
ckulchar's Avatar
Duke
What would you recomend for rods? Should I do anything special to the heads?
Thanks again
Old 11-05-2005, 09:13 AM
66BBCoupe
66BBCoupe's Avatar
2023 C1 of the Year Winner - Modified
2021 C2 of the Year Winner - Unmodified
Recently had my 1966 427/425 rebuilt - used TRW forged pistons (full float pins), H-Beam race rods and an NOS 223 crank. Very happy with the results.
Old 11-05-2005, 10:23 AM
SWCDuke
SWCDuke's Avatar
AFAIK the 396 rods are okay for street use and 6500 revs, but definitely have them Magnaflux inspected. I don't think they're fundamentally weak like the early 327 rods, but you should ask Clem Zahrobsky. If there's any doubt in their durability, I would go with Crower Sportsman rods like I recommend for mechanical lifter 327s.
As far as heads are concerned I recommend pocket porting/port matching and a multiangle valve job for ALL Corvette engines if you want "more power". It's good for 5-10 percent more at the top end with less rolloff to the redline, and doesn't effect visual appearance or idle characteristics and low end torque.
Duke
To Zollner Pistons would you use?
Quick Reply: Zollner Pistons would you use?
