another garage question - floor
Tile guy claims that the "industrial tile" should do just fine. I also am in a cold area but my floors are heated which he said would make a positive difference. I have three tiles down to try them out before I commit. Thinking of doing the work area first, sees some use but no 3-4 thousand lb cars turning the wheels. At $0.63 a square foot it seems to be woth a shot. Also the choice of colors is amazing. I'm sure the price will doulbe by the time I finish with the adheasive and finish coat but I like the look and still less then half the cost of race deck.
Received 2,136 Likes
Since I adding on to the house for a enlarged garage, I think I going to go the way of Capevettes. Do you know the actual maker of the tiles? Dennis
St. Jude Donor '05
JohnZ,
I definitely see 2 items in your garage I wish were in mine...the Z (tell us more; original motor? colors? is that where the Z comes from in your handle?) and the Sunoco pump. Sunoco has always been my fuel of choice.
Originally Posted by joec
www.racedeck.com They make the tile floors for garages.. They aint cheap tho...
/joe
/joe
I highly recommend RaceDeck. If you shop around, you can get it for about $2.75 sq. ft. I've had it for years and love it. Under the RaceDeck is peeling/lifting epoxy that was applied after pressure washing and acid etching.http://i8.photobucket.com/albums/a17...1Image0018.jpg
Received 1,859 Likes
Originally Posted by ZRGator
JohnZ,
