[photos] Finished work on trailer for transport of 63..
Since the 63 is coming home next week (4 days and counting), I finished work on the trailer for now...thought I would share my photos of what I did...
Inside the trailer. Put down vinyl black and white checkerboards, primed and painted the walls, and starting to put up "History of the Corvette" wall boarder..
Notice the non-skid on the loading ramp...
Next photo shows inside...waiting for more boarder to finish both sides, carpeted the wheel wells...and will put bumper pad for door on the wall.
Final photo, installed the winch..powered by truck battery...put some diamond plate on the floor both on top and bottom for support...
Think it will be a fitting transport for my 63......
Cruising
Hi -
It looks good. Do you recall the manufacturer's name of the black / white vinyl tile? I've been looking, but no one seems to carry square commercial grade black and white tiles. I want to do something similar to my new 22 foot Haulmark and a garage. The garage will need heavy duty because of the wheels on the 4 post lift, engine hoists, etc. The manufacturers that I've called don't think their vinyl can take that kind of load. I know that it's made, but I don't know by whom. If anyone has a clue, could you please let me know. Thanks
Also - I had to build ramps both leading to the drop down door and inside the box to load some really low cars - a 96 Corvette GS and 96 Dodge Viper GTS. The inside ramps allow the escape door to be used. Neither car had a chance of clearing the loading door. The older Vettes can make it easy.
I got the vinyl squares on line...I will try to find the people I got if from, but I think I just googled black and white floor tile....
Recommend you rethink putting these down on garage..putting it on painted wood and concrete are two different things. I don't thing the vinyl would be any good on pourous concrete. I used race deck flooring and am very satisfied...
Why a trailer?
What were your reasons for a trailer?
- Is the car now too nice to drive?
- Do you feel that you have too much invested in the car?
- Is it to maintain cleanliness prior to judging?
Not meant as a criticsm, just out of curiosity.
Originally Posted by CaptRon
I've been looking, but no one seems to carry square commercial grade black and white tiles......
One other thing to be careful of is lifting a car with independent suspension (especially the rear) and then setting it back down on the tile. Because of the suspension geometry, there is a lot of sideways force applied the tile when the suspension is lowered to the floor, usually enough to move the tile sideways. I learned this the hard way and now I usually place a piece of cardboard under all the tires when I lower a car on my lift so that the tires can "slide" on top of the tile.
Charles
Very Good Questions and here is my reasoning
No criticsm taken, we all are different and have different ways of looking at things. I have been showing cars for many years and this is the first trailer I ever bought. I have always driven to and from shows. So I can understand your reasoning for asking these questions.
My wife and I hope to travel to different parts of the country to attend some of these wonderful shows and cruises, like the Route 66 San Berdeno Show, Woodward Cruise, Gold Coast Cruise, the NCRS Show in Kissinemme, Fl, and so on. I like attending local shows, and the car will be driven to the local cruises and shows, but like I said, its not practical to drive this car on long distances because of it being a 63 Coupe, no air, no power, just the horsepower and stickshift.
Its a fully restored (show room condition) 1963 Split Window Coupe. These cars are getting scarce and I hope to preserve it for longer trips. I have purchase ET Wheesl and Radial Red line tires to use it for cruising, while in show it will have the bias tires White Walls and its original wheel covers. I enjoy driving, and I did not creat a piece of furniture, but at the same time I don't want to drive it long distances.
By all means, it was a VERY VERY expensive and time consuming frame off restoration. But as I stated about, its not furniture, Corvettes are meant to run and it will run.
No, I did not rebuild this car to be a trailer queen, it will be driven and enjoyed. I have no problem detailing cars for shows, been doing it for years and years. A little soap and water and Zaino does wonders. Matter of fact I enjoy working or detailing cars...that has no issue. But I have to say this, trailering it to shows gives you the added protect if it should rain you can get the car into shelter...many times I have been at shows where it just rain, I would cover it up, redetail and it would just rain again...that is a definite benifit.
Cruising
I think most of the trailer companies (Haulmark, Pace) use sheet vinyl. Any known sources for that material?
Cruising
Originally Posted by cbernhardt
I covered the floor of my new shop with commercial grade vinyl tile that I found at a building surplus outlet. I guess they buy the excess from commercial building products. My two post lift is fixed but I do occasionally lift one end of a car with a floor jack. So far the tile has stood up well to the weight of the jack but I would guess that something like a moveable four post lift might leave indentations if you left it sitting on the rollers for any length of time. The only problem I have with the vinyl is that it will discolor if you leave any rubber tire on it for more than a few hours. I have a nice big brown ring on my floor where I stacked some new tires and even my rubber tired roll around carts will leave marks.
Charles
Charles
Ron
Just some advice for others putting vinyl tile in a car trailer. Make sure you get tile that has the color all the way through the tile. DON'T get the tiles with the thin color film on top of a vinyl base. They won't last.. ask me how i know... I think this is what people mean when they say commercial tile, the tile is a solid color throughout... Don't save money buying the wrong tile.
