1967 "427" 400HP, hesitation
This 1967 427/390/converted to 400 just got out of the shop. I rebuilt the engine, transmissiom, driveline, front end, radiator, on infinititum.
The engine was reassembled with 9.25 CR pistons and some head work was done. The 400 manifold must be made out of gold, because that's what it cost. The carburators are all new Holly.
Everything is very tight and I need to get some miles on the car to loosen it up a little. I've had this car forever and driven it 150,000 miles. So, an overhaul was due. It is SO tight now. HOWEVER!
It has a hesitation, stumble, terrible drivability, off the line. Between 700 and 1400 RPM it just bogs down. It runs much better cold when it is getting choke so I believe it need more GAS.
What should I do?
Karl
What should I do?
Karl
BTW, doesn't it look nice without the front plate. I live in Washington where a front plate is required EXCEPT for "classic" cars over 25 years old.
The car is registered only ONCE, money will never come due again, gets a special plate for the REAR only. Best thing I've ever seen the WASHDOL do!
One other thing, the engine shop was able to overhaul the ORIGINAL engine and not deck off the "ALL" important NUMBERS!
Sorry for taking up so much bandwidth! But it is SO fun to have this midyear back. I HATE the term C2. What moron thought THAT up?
I'm with you on that. As far as I'm concerned there are 3 types of Corvettes.... Straight-Axles, Mid-Years, and Junk.
Oooppppssss...... running for the door.
Check all the usual suspects.
Timing advance; not just at idle (vac can disconnected) but see to it that you get 36-38 degrees total.
Points; condition with stable dwell (28-32 deg). Check for excessive dist shaft wobble.
Plugs; fouling? heat range.
Vacume advance can; working or not, pin starts to move at 6-7 inches of hg and bottoms out at 14-15 inches of hg.
Centrifugal advance; stuck? weights binding on pivot pins?
Coil; intermitent short/open as engine temp goes up.
Secondary carbs; closing tight, not sucking air.
All specs are in the '67 CSM.
Received 1,857 Likes
Connect the vacuum advance to the choke vacuum break hose with a tee so it sees full manifold vacuum; the stock configuration is "ported" vacuum. Big difference.
Thanks for the tips 67L36Driver. I'll have my mechanic check this.
And JohnZ, thanks as well.
JohnZ, can you elaborate a little on just where the takeoff point for the stronger vacuum is? My choke is thermal, I think. And I don't have power brakes.
Thanks,
Karl
Thanks,
Karl
St. Jude Donor '05
[Sorry for taking up so much bandwidth! But it is SO fun to have this midyear back. I HATE the term C2. What moron thought THAT up?[/QUOTE]
I just had my 427/400 in the shop and the carbs were rebuilt. The problem of the "bog" my guy attributed to the jets. The stock jets were replaced with slightly larger pieces. The car runs like a raped ape now.
BTW, I agree with you on the C2 term . My car is a midyear and I'll always call it that. Good luck with the bog, I'm sure you'll get it fixed.
Thanks,
Karl
Thanks,
Karl
John, Great photo. Thanks.
I took this to Del, my mechanic. He is very good and completely understands.
However, he wants me to put 500 miles on the car and try to get it running with standard GM specs. Then, if that won't work out he's willing to relocate the vacuum and re-jet the carb.
Sounds reasonable to me, except the part to run around with the hesitation for 500 miles!
Best
Best
OK John.
It's funny. There already was a "T" off that choke line that was capped off. So I just hooked up the distributer with a short length of hose and capped off the old source.
I does run with less hesitation, but it also idles faster and now runs on when i turn off the engine. It might just be running with less hesitation because of the 1200 RPM idle---I don't know.
Sure is fun driving it around again. Especially since it is no longer my only car!
Best,
Karl
Best,
Karl
OK John.
I does run with less hesitation, but it also idles faster and now runs on when i turn off the engine. It might just be running with less hesitation because of the 1200 RPM idle---I don't know. Best,
Karl
Karl
OK, JohnZ!
Couple of stupid questions.
1. What kind of vacuum gauge should I buy at Sears?
2. To which vaccum port should I attach it while adjusting the idle mixture?
Thanks again for your help.
Karl
Karl
Roy
OK, JohnZ!
Karl
Karl
