Shocks???
Shocks???
I'm ready to get shocks for my 63' driver with a 7-leaf rear spring and coil front (have no idea what the front springs are, but they are not stock).
Considering KYB gas shocks @ $150.00 or AC Delco gas @ $120.00 set. I know that the Bilstiens are pricy but not sure whether my use would justify the cost.
The car will be used only for cruising around town and an occasional romp here or there. No track racing or slalom. I don't have alot of experience with "road performance" as it were.
Any opinions as to shock performance vs price or any other input in this area would be appreciated!
Thanks, Mike
Thanks, Mike
The AC Delco are junk.... They are if I'm remembering my last conversation about them just Gabriel Gas shocks.. All that has been done is a AC Delco sticker stuck on them.. I put Bilstiens on mine and the difference is dramatic, well worth the intial buy in.. I have a composite rear spring though and that makes a lot of difference. If it was me buy the Bilstiens or the KYB's, there is another that Duke recommends but I can't think of it right now... Dave..
Duke likes Spax, in part because they are adjustable, as I recall
I have the Bilstein Sports all around, and I toss my 65 into corners quite often and am happy with the results (of course, tires / shocks / springs should all be chosen to function well together, and will be as good as the weekest link.)
Ooops!
So, are these Perelli 4000 tires still available? I've seen alot of conversation about them. Whats a good combination when starting from scratch, Tires, shocks, etc.? Never heard of SPAX either.
Mike
Received 2,161 Likes
In your case the tires should come first since they are dangerously old. The shocks can be next, too many to choose from. Another simple addition is to put urethane bushings on the front sway bar and or install a rear bar. All add up to increased handling with min. cost and labor. Good luck! Dennis
Poly,
I may be speaking out of turn but I thought that unless you go to a bigger front bar adding a rear bar was a bad idea?? Just thinking out loud here.... As for tires they make a BIG difference in handling... Dave...
Pirelli 400o tires are still available and worth the investment. There are reports of their demise but I had no problem finding them, installing them and for the last 2 weeks, enjoying the heck out of them.
And who cares if they stop making them, the set you buy now will be used for ___ years anyway.
Not set up for performance...
I plan on keeping what I have (hardware), but will need to find the best tire, shock combo that I can to work with what I have. Where did you get your Perelli's? Are they available at any tire outlet or can they be ordered from their website?
FWIW I have Bilstein Heavy Duty shocks and love them. They ride exactly as I recall the original shocks riding back when midyears were new. I've gone to one track event, a driving school, and the shocks were not a problem at all. The two driving instructors who drove my 67 roadster said it felt great at high and low speeds to them. All of my driving is of the normal kind, except that I take one long drive each year, for several thousand miles. I have the 9-leaf spring. If you go with Bilsteins, make sure to get the Heavy Duty shocks, not the Sport shocks. The names are backwards, because the HD shocks are meant for the street and have a normal ride, while the Sport shocks are meant for the track/autocross and ride pretty rough for most folks.
Thanks, Mike
Thanks, Mike
.......I have the Bilstein Sports all around, and I toss my 65 into corners quite often and am happy with the results ...
I did get poly for the sway bar end links front, and poly for the rear leaf ends, and the t-arms. I had not considered a rear sway bar. I do intend to get new tires. They just seem to be so far into the future. But I guess I am getting close to a rolling chassis (with the old tires).
My Original Parts...
Originally Posted by 66427-450
what front bar were you planning on using? i have a very clean stock BB (7/8") front bar off my car if you're interested.
Fact is, I don't yet know if a larger sway bar would be a benefit to me or not. Though I will keep this thread in the event that I learn more as I begin to drive this car a little harder.
I have always treated the car like it was made of fine crystal for some reason????? :o
Thanks, Mike
...I plan on keeping what I have (hardware), but will need to find the best tire, shock combo that I can to work with what I have. Where did you get your Perelli's? Are they available at any tire outlet or can they be ordered from their website?
I did a google search for pirelli tires bremerton washington and it was not quite specific enough. I bet you can call tire shops in your area and they'll know who carries Pirelli and probably direct you to them.
I also got a few results from mail order shops ---here they are:
Pirelli Tire
Find the Right Pirelli Tires for
Your Car, SUV or Pickup- Learn More
www.us.pirelli.com Pirelli Tire Dealer
Shop for Tires & Wheels by Vehicle.
Research & Compare - Great Prices.
www.TireRack.com Pirelli Tires
Order Pirelli Tires Online With
Discount Prices and Fast Shipping
www.TireSavings.com
Good luck!
Goodness!
You guys are hitting me right in the wallet!!!
Sounds like everyone likes the "Bil's".
One good thing is, my wife asks me "what do all the guys on the forum say?".
No intent to steal the thread, but a word on tires. I left the tires that came on my '65 on the car. They looked good, plenty of tread. Went several laps around TMS that May at 100-120MPH. The same July 4th my son borrowed the car, had a blowout and tread seperation that completely destroyed the LR corner of the car. Needless to say the damage was extensive. I rebuilt the rear suspension at that time. I'm not completely happy with the Delco shocks installed, but they're still there.
