Go Back   Corvette Forum > C1 & C2 Corvettes, 1953 - 1967 > C1 & C2 Corvettes
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C1 & C2 Corvettes
General C1 Corvette & C2 Corvette Discussion, Technical Info, Performance Upgrades, Project Builds, Restorations Sponsored by
Flaming River
Industries
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-09-2005, 02:37 PM   #1
toddalin
CF Senior Member
Default Accessory Bolt Holes for Camel Hump Heads???
Has anyone welded nuts or even drilled and tapped holes to install "accessory bolts" on camel hump heads?
I'm toying with adding a supercharger that requires those mount points but don't want to give up my nice, modified camel hump heads.
Seems that with a template, it would be fairly easy to weld some nuts to the heads. Can it be done without removing the heads? Do the fronts of "accessory bolt" heads project out to the same point as a camel hump head, or would I be able to account for this?
Would like to hear from anyone with experience.
toddalin is offline   Reply With Quote
Old 04-09-2005, 05:09 PM   #2
vetzs
CF Senior Member
Support Corvetteforum!
vetzs's Avatar
I think I would consider some custom made brackets for mounting to exisiting bolts on the block. Maybe billet? This could look really trick and eliminate any problems with the welds or wanting to go back to original.
vetzs is offline   Reply With Quote
Old 04-09-2005, 05:24 PM   #3
Corbrastang
CF Senior Member
Buy some of summits new aftermarket cast heads. they outperform the original camel hump heads and have accesory holes
Corbrastang is offline   Reply With Quote
Old 04-09-2005, 05:31 PM   #4
don peters
CF Senior Member
Default ci heads
successfully welding anything to cast iron heads is at best a crap shoot. I would not have any confidence with any welds for mounting. Just repairing a crack is a hit and miss operation. Aftermarket heads is the way to go.
Don
don peters is offline   Reply With Quote
Old 04-10-2005, 12:40 AM   #5
Plasticman
CF Senior Member
Plasticman's Avatar
Send a message via ICQ to Plasticman Send a message via AIM to Plasticman
Yes, I have tapped a hole into the camel hump heads for mounting purposes. But I also made a spacer (out of aluminum) that conformed to the head contour, and then provided a flat face for whatever I was mounting (acted like a removable boss). Time consuming to make the spacer, but worked like a charm for many years on a daily driven street vehicle.
I would not try welding anything to the cast iron of the head. It is possible with a high nickel content rod, but then head should be preheated, etc., and then always the possibility of warpage.
Plasticman
Plasticman is offline   Reply With Quote
Old 04-10-2005, 07:03 AM   #6
MikeM
CF Senior Member
I did it once. Made a template and drilled and tapped the holes. I didn't do anything fancy like Plasticman. I just used washers for proper spacing. I'm not real proud of it but it ran for a long time with no problems.
MikeM is offline   Reply With Quote
Old 04-10-2005, 11:14 AM   #7
66427-450
CF Senior Member
66427-450's Avatar
Send a message via AIM to 66427-450
well.......... if your adding a supercharger, i surely would get some aftermarket high flow alum heads (why cut up a good set of originals???)
66427-450 is offline   Reply With Quote
Old 04-10-2005, 01:17 PM   #8
toddalin
CF Senior Member
Thanks, Plast and Mike. How deep can one SAFELY drill into the heads to tap a thread?
As for those who responded that I should change heads, I see no need to add an additional $1,000+ to the project. My heads were "cut up" long ago, if that's what you call professional pocket porting, port matching, hardened seats, and 3-angle valve job. Car does about 300 hp at the wheels (293 on the dyno prior to a Lars tune-up and some carb work), so there is really nothing wrong with these heads that warrants the addional $$$ outlay.Click the image to open in full size.
Old 04-10-2005, 02:37 PM   #9
MikeM
CF Senior Member
Just because I now think you are serious, I'd like to add something. If you are going to hang a blower off these added holes, I'd give this some serious thought. I don't remember what I used the added holes for, only that I was using a set of 64 cc heads to raise the compression on my pitifully slow new '71 pickup. A blower running under boost would have much more strain on these attachments than what I was doing. If you do this, make sure everything is square and not in a bind. Just using flat washers against the cast surface of the head would probably not be a good idea for something that had a lot of strain against it. no reason the washers couldn't be brazed to the head. You could probably use a four inch grinder to flatten the cast surface of your heads to make sure your barcket was against a flat surface.
As far as drilling too far, I see no reason you can't go into the water jackets and use Permatex to seal the thread holes. Just don't drill into the combustion chamber. You may want to use studs in the heads instead of bolts.
If you want to return the heads to stock configuration, all you have to do is put the right head on the left and the left on the right.
Please promise me you will tell NOONE I told you you could do do this!
Old 04-10-2005, 07:39 PM   #10
Plasticman
CF Senior Member
Plasticman's Avatar
I agree that a supercharger will add to the stress! The holes I added were used for mounting an alternator (a lot less stress). As for depth, I did a bit of measuring and did not protrude into a water jacket or oil area. I will estimate (from a failing memory and a long time ago), that the holes were about 1/2" deep or more (deep enough for proper thread engagement on a 3/8"-16 bolt). Studs are an excellant suggestion, but may cause other mounting problems. As long as the mount ties in with at least 2 points (3 is better) on the head, and also off the water pump mounting bolts, I would think that should work with a supercharger.
When working with holes that are of minimum depth, you will need to finish off the threads with a "bottoming" tap, so you get threads pretty close to the bottom of the hole for max thread engagement.
However, a better question is what compression ratio are you planning on running with the supercharger? I added a Paxton supercharger to a SBC (on a buddy's 66 Avanti II) using the above mounting points, but the heads were later models (we needed a lower compression ratio) with the front mounting holes.
In other words, you may think about changing over to later model heads for the same reason (lower the compression ratio for the supercharger and gain the mounting points all at once). Some of the 70's & 80's era iron SBC heads are decent for that application (and some are terrible!). You probably want about a 9:1 compression ratio depending upon boost (the higher the boost, the lower the ratio should be - or use very high octane fuel). You would also gain the induction hardened valve seats that are probably a necessity for blower usage.
My twin turbo'd boat ran 8.5:1 CR with up to 7 pounds boost, and had a knock sensor, which warned me when I was detonating. Still went through an engine - cracked piston from detonation (but 72 MPH in a pretty heavy 23' cruiser with a 350 SBC was impressive).
Good luck on your project.
plasticman
Old 04-10-2005, 09:20 PM   #11
MikeM
CF Senior Member
plasticman
I think I told you this once before. Impressive!
Old 04-11-2005, 01:01 PM   #12
toddalin
CF Senior Member
Thanks guys, compression was reduced to 9.5:1 when the heads were done. A bit high for a blower, not not incredably.
I'm considering the Procharger unit that looks like the old fuelie setup and sits in the center above the intake manifold, and I believe that the system ties in to both heads, so it doesn't put the strain on a single head like a side-hung unit. The blower is designed to mount to a ZZ-4.
Old 04-12-2005, 01:05 PM   #13
65air_coupe
CF Senior Member
65air_coupe's Avatar
What I did for the mounts needed with a serpentine belt conversion was to bore 1/2" diameter holes where I needed and then made threaded 1/2 diameter spacers that were TIG welded in places with high nickel rod. A little work with a dremel tool to turn the welds into fillets and they now look like they were cast that way.
65air_coupe is offline   Reply With Quote
Old 04-12-2005, 02:56 PM   #14
Seaside63
CF Senior Member
Check the street rod and hot rod magazines.
There are some very nice accessory drive brackets available now. I'm sure you can even get one custom made.
It would look better and be stronger than mangling your heads.
Seaside63 is offline   Reply With Quote
Reload this Page Accessory Bolt Holes for Camel Hump Heads???
Tags
accessory, adding, bolt, camel, camelhump, double, drill, heads, hole, holes, hump, mounting, paxton, procharger, sbc, template
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Centrifugal SC in a C3 ENCHANTMENT C3 Tech/Performance 12 04-02-2005 12:05 AM
Double Hump Heads SKYCOP1 C3 Tech/Performance 22 07-05-2004 12:13 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
