Drop base air cleaner
For those that are using an aftermarket air cleaner, what are you doing for crankcase ventilation?
PO had punched two holes in the base of my air cleaner to clear the Holley float needle screws and given that that top needs replating, I was thinking of just going to an aftermarket, drop base air cleaner. But when looking through the selection at my FLAPS, I realized none have any provisions for crankcase ventilation.
Punched 2 holes... WTF?! The correct air GM cleaner worked with the Holley the car came with, why did he need holes? Can you patch them, or would that interfere with the filter element? If you can patch them, why not just buy a new top for yours?
Location: At my Bar drinking and wrenching in Lafayette Colorado
Received 4,924 Likes
The purpose of the tube from the air cleaner to the valve cover is to allow the engine to draw clean, filtered air into the crankcase during normal operation, and to capture and recirculate emitted crankcase vapors when at WOT (when flow reverses through the tube due to elimination of PCV valve vacuum). You can get the same effective crankcase ventilation by retaining the PCV valve and using a standard breather in the valve cover instead of the tube. Although the breathers do not look stock, they do provide effective filtering of the air for the PCV system, and they do prevent excessive oil discharge at WOT. Of course, you need to retain the PCV valve for this to work right.
I have found that the stock PCV tube in the stock air cleaner can interfere with aftermarket carb secondary accel pump linkage, and the breather system is a good alternate method to keep the PCV system operational. K&N makes a good drop-base air cleaner with a 3" element that allows use of a pretty tall manifold on a stock C2.
I suppose one could retrofit a PCV system into this vintage. Is that what is being down to run an aftermarket air filter?
Originally Posted by 65air_coupe
To the best of my knowledge, these cars were not equipped with PCV systems, and as such, the have neither PCV valves nor vented valve covers. They were one step better than the old down draft tube of the 50's, in that they attempted to draw crankcase vapors into the carb by routing the vented air from the lifter valley into the low pressure plenum within the air cleaner between the air horn of the carb and the filter element. A smaller tube ran from the plenum inside the air cleaner but outside of the filter element to a spigot on the side of the oil fill tube.
Thanks Vetterodder, I wasn't aware of what you've described. I need to look at my AIM and re-educate myself on how it was equipped originally. So far the aftermarket air cleaners I've seen have no provisions for PCV, I think I need to look at the local speed shop.
I found the same secondary pump interfered as well, however with a little heat one can easily modify the steel tube to provide pump linkage clearance.
Do you have the correct valve covers? If so, then just use the correct air cleaner base for your car. Then you can buy that and the hose that connects them. Call your favorite Corvette parts vendor; give them your credit card number; and, voila, a package arrives on your doorstep with all the solution to this problem.
Thanks for responding Chris. I will look again at those air cleaners, more carefully this time. I have the correct valve covers (finned cast al.), but the crankcase vent is at the rear of the block, not thru the valve cover.
I gather that I need to buy an aftermarket PCV valve and tee it into the line at the base of the carb to complete the system?
I have the stock oil filler tube with the fitting. At the moment, I'm planning on connecting a line from the carb base to this fitting with an inline PCV valve.
I did find and buy an aftermarket air cleaner with the knockout and fitting. Connecting that to the existing ventilation tube may take some doing, but I'm sure I can handle it.
I'm not familiar with 65s. But it sounds like you've got a hose from the base of the carb to the oil fill tube on the front of the intake manifold. That'd be the vacuum side. The PCV valve would be plumbed somewhere in line there. Then filtered fresh air is supplied to the crankcase from a hose that goes from the base of the air cleaner to a fitting on the back of the block, just behind the distributor. And it sounds like you've found an air cleaner base with provisions for the nipple. You have the oil fill tube with the fitting for the hose. There is a hose fitting that goes in that hole on the back of the block. Check your parts catalogs if you don't have it.
With all that, you should be able to put something together that'll work. Try heater hose for the PCV hose. Heater hose usually comes in 5/8" and 3/4". One of those sizes is slightly too big, but it'll work. You'll have to rotate the air cleaner base around so that the nipple and the hose don't interfere with the carb or choke linkage. You can buy the correct hose from the parts suppliers.
