If you had your choice, would you run 17 or 18 inch rims in front for hpde?
Old 11-26-2004, 09:20 PM
Dr Chill
Dr Chill's Avatar
Default If you had your choice, would you run 17 or 18 inch rims in front for hpde?
Also, what width rims with what size tires? I think using 305/30/18's all around would make it easier and may help handling. Do you guys agree or should I stick with a staggered setup? The car will be used 4 times a year on the track with r compound tires on these rims. Thanks to all those with vast amounts of track time who contribute to this forum. I think I will have my car setup pretty good having never run a C5 before with just the info from you guys.
Old 11-26-2004, 10:11 PM
AU N EGL
AU N EGL's Avatar
I use 18 in in all four corners for both street and track
street are 18x10 rims with 18x275-35 Mich PS f and rear are 18-11 1/2 with 18x335-30 Mich PS
track are 18x11 rims with 18x315-35 GY or 18x-285-30 Hoosiers front and rear are 18x12 rim with 18x315-35 GY or 18x335-30 Hoosiers.
I dont think the stagared set up is nesscessary. The T-1 races use 17 in in all four corners and they seam to get around quite fast.
Old 11-26-2004, 10:45 PM
MUKAK
MUKAK's Avatar
u will be better of with 17 GS wheels all the way around simply cuzz there is more tires avail for the 17 inch wheels and they are cheaper
Old 11-26-2004, 10:53 PM
Dr Chill
Dr Chill's Avatar
What are GS wheels and are front and rear the same width?
Old 11-26-2004, 11:31 PM
MUKAK
MUKAK's Avatar
GRANS SPORT
factory are 17x9.5 front and 17x11 back
but u could run 17x11 all 4 corners with 315s on them
Old 11-27-2004, 06:58 AM
AU N EGL
AU N EGL's Avatar
Here some one is selling some over in the C5 parts forum
http://forums.corvetteforum.com/showthread.php?t=956393
Old 11-27-2004, 12:30 PM
zrracer
zrracer's Avatar
St. Jude Donor '11, '14
If you get 18, rims and dicide in the future that you want to run some R480 tires or non DOT tires you will be all set. If you get the 17' rims and then want some stickies you will have to get some 18'ers.
Robin
Old 11-27-2004, 10:50 PM
levettegrl
levettegrl's Avatar
Cruise-In IV Veteran
I run 18's all around
Old 11-28-2004, 04:59 AM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
CCW with 18 x 12 will let you run a vast amount of tires including some real slicks as said above in 380 or 480 GY compounds. Same on both ends (all 4).
Old 11-29-2004, 07:00 PM
Gary2KC5
Gary2KC5's Avatar
The stagger size is just for looks. The SCCA racers seem to think 17's all around is the setup. Whats works for them? cost? handling? better gearing?
I always thought the only advantage to 18's all around was you could run bigger front rotors.
Why is 18 in front better than 17 in back?
To If you had your choice, would you run 17 or 18 inch rims in front for hpde?
Quick Reply: If you had your choice, would you run 17 or 18 inch rims in front for hpde?
