Racing Log Book
Racing Log Book
Anyone have a log book to track your racing events? Event info, results, car setup (tire pressure, etc.). Some thing I could borrow (template)? Or know where I can get one. I've searched all over the web but just can't find anything useful.
Make up your own. That's what I did in a spiral notebook. I also transfer that info to the computer. I make notes about the run group I was assigned to, who my instructor was, his address if I can get it and his club affiliation, when I was signed off to run solo, track conditions i.e. air temperatures, clear/cloudy/rain, tire pressures, what I sensed the car doing during certain runs, people I met, maintenance I did to the car prior to going to the event, brakes pad measurements, what brake fluid I used, all of that kind of stuff.
Pretty much what you think might be important when you review it later in the year or the next time you go to that track.
Yeah, I know. I've tried, but I just can't seem to put something together that I like. I was hoping someone had a template I could borrow and modify it as needed. Any way you can show me what you have?
TTT
TTT
Racing Log Book
Discoveryparts.com has a log they send out with each order.
Has things like:
event, date, track temp O.A.T. Barp Humidity
oil brand weight temp fuel octane amount before and after event
carbs or injectors pression
tires air pression cold hot
spring lbs lf rf lr rr
camber lf rf lr rr
caster lf rf lr rr
cold psi cold temp
hot psi hot temp 3 reads across tire
Fuel at begining and end
water temp oil time pil pression
notes
lap times
Has things like:
camber lf rf lr rr
caster lf rf lr rr
cold psi cold temp
notes
lap times
