SCCA BSP C4 Vette setup
I am moving to BSP this season, as my long-tubes have made me illegal for stock. I was wondering what kind of mods guys running nationally at the BSP level where using?
Re: SCCA BSP C4 Vette setup (rsafier)
Competitive cars will have a setup that will look like this:
-17x12 wheels front and rear; 315/335 Hoosiers; varies upon driver preference
-vette brakes xtreme springs; ~1200f, ~600r
-poly/delrin everywhere in the suspension except for the differential.
-offset front lower control arm bushings for obscene camber
-30mm front and 22mm rear swaybars; or adjustable
-Z51 steering rack
-Penske S/A, D/A, or T/A; JRZ, Koni D/A shocks are the usual suspects...
-aluminum flywheel
-3.54 gears
-lightweight exhaust
That's the basic setup, but there's a lot more to it than that though... ;)
Nick
-Z51 steering rack
-aluminum flywheel
-3.54 gears
Nick
Re: SCCA BSP C4 Vette setup (Nick C)
:crazy: Yeah, I'm glad I rarely see those setups at my local events, would be a brutal killing.
How much camber is "obscene"? After a little work I was able to get mine to -1.5 in the front without starting to mill down the aluminum inserts. Figure I could get 2.5-3 if I milled those down. Still have +5 caster without any shims other then those to even out the camber differences between the sides.
[QUOTE] :crazy: Yeah, I'm glad I rarely see those setups at my local events, would be a brutal killing.
QUOTE]
Yeah, welcome to my world.... NorCal is the BSP capitol of the country, hehe.
Don't touch those spacers though, not legal in BSP. Have to use the bushings in order to get that camber. I usually run -2.5 and could probably max out at a little over -3 degrees if I wanted. -2.5 camber usually translates to just a hair under 8 degrees of caster. Check out the rulebook before messing with the car too!
Nick
QUOTE]
Nick
You're right Nick about those spacers. People spend $500 when it's all said and done to get serious negative camber. Why wouldn't SCCA want BSP'ers to achieve the same result for free by tweaking the upper control arm spacers? IMO, buddies of the Comp board in the offset lower control arm bushing business.
[Modified by h rocks, 1:38 AM 3/4/2004]
Re: SCCA BSP C4 Vette setup (h rocks)
I guess its the road racing guys that told me that I could do that to get extra camber, will have to read the BSP rules again. Because one side of the car has about 1/2 degree more then the other as it is now.
I really do need to replace my bushings at some point, being 19 years old they are pretty worn. Just don't have the cash for it. How much more are offset bushings then your standard poly replacements?
I wouldn't futz with the offset bushings unless you do a hundred other things to your car, and you plan on using it ONLY for A-X. Once you lower the car, you will be able to get a good -2* camber up front. Rear is no problem. At -2* you will chew up tires if you drive the car relatively straight (interstate travel) The offset bushings are for HARD CORE dedicated autocrossers only. You don't need that much neg camber to run a roadcourse.
BTW, when you dump those squashed out old stock bushings, check out Global West Del-alum bushings. They are awesome, and will likely be the last set of bushings you will ever need to buy, regardless of how you use the car.
[Modified by h rocks, 9:35 AM 3/4/2004]
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
The cheap mod is legal in SM2.
Of course, then your running in SM2, all the BSP mods plus a lot more.
If you wanted to get into some engine & drivetrain mods, I'd consider it.
Re: SCCA BSP C4 Vette setup (Goody)
The fastest BSP cars continually run KUMHO Tires :yesnod:
The winningest (word?) current BSP car in National Competition is the NayKid Racing KUMHO Tire 89 Corvette of Moffet/Buetow
The car is currently running fastest on 295/40x17 V710 KUMHOs on all four corners. The key to running smaller tires is the amazing grip of the V710 and the ability to make the car smaller (read more Lotus like) and narrower as opposed to making the car huge wide with 335's
This car has won 3 National Solo titles and won again last weekend at SanDiego in BSP & BSPL displacing last years Solo BSP Champ Tom Berry who hit cones all weekend on 335/315 combo :thumbs:
Oh BTW 11" wheels all around...
sbw
[Modified by Scotty B, 8:24 AM 3/10/2004]
sbw
Re: SCCA BSP C4 Vette setup (Scotty B)
Yeah been reading great things about the V710. I have a set sitting in my garage just waiting for the season to begin. I had about 1/3 life left in my Victoracers but got lucky a guy in my AutoX club needed a set for MidOhio in a couple weeks, so bought mine off me! Look very aggresive, can't wait to try them.
Don't have the money to get new wheels just yet, so still running on my extra set of 265/45/16s. Hopefully by the time I run thru this set of tires I will be able to afford getting a nice lightweight set of 17s. Stock 16x9.5s aren't exactly light.
I was wondering how much life are people getting out of there V710s? Or do most of the national guys just use a set for the weekend and get new ones (something I certianly will not be doing). I would expect quicker wear compared to the Victos as they are only 30 wear-rating compared to 50, but how much is this? Can I expect them to last 10 events many with a co-driver? How is grip after heatcycling, hopefully like the Victos which I though was pretty consistent?
The easy way to get more negative camber is to use 84-87 upper control arms. They are shorter than the 88-96 and give the same amount of camber as offset bushings. You can combine the two and be really obscene. I think that -3 camber is all you would ever need, but you could not drive that on the street. I run -1.6 and I eat thru tires fast. Higher tire pressures reduce the inner wear associated with negative camber.
A big key to running BSP (autox in general) is to get the car as light as possible. Relocating a light battery to the rear is good. Racing seats can save more than fifty pounds. I knew a guy that got a 96 under 3100 lbs.
