Differential cooler fitting question
For those of you that have replaced the drain/pickup tube fitting on the differential with an AN fitting, what fitting did you use? I know that the other ports are 6AN/6ORB fittings.
Is it a M20x1.5 thread or an o-ring port fitting?
Here is a pic of the fitting I am referring to. TIA
I believe for my c5z (not c6) it is AN8-8AN AN-8 to M20 x 1.5, I have a spare fitting and diff in my storage space and will confirm later today. I'd imagine the sizing hasn't changed much but maybe someone else can chime in here.
Diff fitting:
-8 AN 20mm 1.5
https://www.pegasusautoracing.com/pr...asp?RecID=5064
Edit: 02/06/2024
Oil cooler fitting below will not fit diff
Diff fitting:
-8 AN 20mm 1.5
Edit: 02/06/2024
-8 AN 20mm 1.5
I ended up getting a DRM kit second hand so my kit is this.
