PDR won’t record lap times
I had this problem before at Road Atlanta and I don’t remember what I did to fix it.
The PDR will start recording but it won’t recognize when a lap has been done. What am I doing wrong or how do I set it up?
There is an option to “mark start/finish”. You press that and then there is a button you press when you are at the start finish line and it will gos locate it to record your lap times.
make sure your pdr mode is set to circuit/track(may be remembering the name wrong.
When you go to start a track recording for the PDR, you have to set it up as a new track. Once you set it as a new track, it will have a button you hit after you cross start/finish after the out lap. The button won't be there unless you are setting up a new track
Not sure if that is your problem or not, but it's a good place to start.
EDIT: Should have known Poor-sha has a video:
Poor-sha (03-02-2024)
Just note that the procedure/interface is slightly different for the C7 (gen 1 PDR) and C8 (gen 2 PDR).
If I'm remembering correctly, you click "circuit" or "autocross" when you get to the start line. After you hit learn, what does it say?
https://youtu.be/pR5u_51K7_4?si=QUJART77dEn9VD8P
I was just getting ready to post up my RA map file. I find it easiest to have a separate SD card for each track so I only have to set it up once.
For the C7 I also use a different card per track, for the C8 and Blackwing I just load them all on the same 256 GB card.
