Trackspec T1 hood louvers
I am looking for hood louvers for my C6. I saw the Trackspec T1 kit which looks fine.
Are there any others of equal or better quality, fit and performance to the T1's I should look at before I pull the trigger?
Thanks!
Thanks!
SteveJewels (05-05-2022)
Received 2,061 Likes
I bought Track Spec, but there is also Race Louvers
Olitho (05-06-2022)
I have not ordered yet.
Larger would be good. The GT2 looks to have rounded edges and corners on the side vents are square. Not sure they would look good together.
I don't like the look of the pop rivets. Any reason I could not use button bolts with double nuts instead of rivets?
SteveJewels (05-06-2022)
This is good advice. Trackspec has numerous other vent styles they can recommend. John at Trackspec is a wealth of information.
I used countersunk M3 screws, to get the screw heads ~flush with the vent. Requires a 90 deg countersink tool.
Details on my T1 install here: https://www.z06.eu/2022/05/trackspec-c1-hood-vent.html
G_Loc (05-13-2022)
