Feedback on Pat G Custom Cam Specs
Received 2,061 Likes
Send it, 43* IVC is key. Going to make good midrange power with that narrow lsa which you want coming off corners, no need to spin it to 7k and can shift it at 6600 like stock.
Hitman227 (04-27-2020)
I'd be concerned with a few things though. First being idle quality and off-idle usability. I forgot but I think you got a manual, so it matters. If you had a, for instance 2800 stall then no, it wouldn't matter..
Second would be valvespring life. I realize that it has endurance lobes, but the lift is more than average, and after all it's designed for power, especially under the curve. But 90% RR is quite some, how many of those equate to how many endurance races ?
Last is emissions. I don't believe you will pass with 10 degrees of overlap, even on a 6.2. You're looking at failing the sniffer test, but of course, does this even matter, depends on the application..
Cam came in today. I'll post some parts pics when I get home.
I have 232/234 @ 112 +4 and I like it, but I've been wondering if a slightly earlier intake closing would have been better. It would mean slightly less peak power, but it would also move the powerband down a little bit, which would be nice for a couple of corners on my home track. And that's basically what you'd get with the specs Pat G provided if installed at +4 rather than the +2 he called for.
So my advice would be to get that cam plus an adjustable timing set. Start with his suggested advance, but check piston-to-valve clearance with 4 degrees more advance. Then run it in the default position, and if you want to trade off some top end for more bottom end, advance it 2 or 4 degrees. I'd like to try advancing mine, but I have no idea how much PTV clearance I have left. (So I raised my rev limiter to 7000 instead. What could possibly go wrong?)
44 degrees at .050. The cam in question would be 43 by default, or 41 or 39 with an extra 2 or 4 degrees of advance.
If you're on a PC, this is handy for running the numbers:
https://cammotion.com/cam-timer
Summit has a web-based version:
https://www.summitracing.com/newsand...ing-calculator
But when when I really want to nerd out, I use Excel.
I just copied it to OneDrive:
https://1drv.ms/x/s!AqB0QOnupiDTgRyn...8ax0w?e=i15StH
The collection of parts so far above. Still waiting on the CHE Trunnion Kit. Then hopefully do the install the last week of May.
Any tips for the installation?
I nerd out to an extent as well. Vettenuts has great topics in C5tech and LS1tech.com on measuring pushrods. Katech has a video as well. I very much recommend measuring them and running the largest diameter the head will clear. 243s is 11/32" I don't know about LS3s. Stability is reliability. I am on a LS6, Johnson 2110s, WCCH Edelbrock 215 cathedrals, CamMotion 232/236 112+2 .612/.612, and 3/8" oil restricted Manton pushrods. The system doesn't have many miles on it, it makes great power and runs great thus far.
Coincidentally EngineLabs has a good Article on lobe design:
https://www.enginelabs.com/engine-te...ogy-cam-magic/
PRE-Z06 (05-03-2020)
Well this is embarrassing, I missed that this is an LS3. What I proposed about more advance might not actually be all that helpful, as the extra displacement vs my LS6 will shift the powerband down a little for the same IVC. I don't know how to quantify that (like how many degrees change per 100 RPM change) but Pat G probably does.
NSFW (05-04-2020)
#33
Melting Slicks<br><img src="/forums/images/ranks/3k-4k.gif" border="0">
St. Jude Donor '11-'24
Pat G speced out a cam for me years ago. It was for a stroked LS2 (402) with L92 heads (pre LS3). He has been doing this for a long time, so I think he has a good handle on what works.
Bob K.
Bob K.
PRE-Z06 (05-04-2020)
#34
If you need to borrow any tools and happen to be passing my way or headed to the track let me know. I think you're on the right path here. I've got the angry xe-r lobe with less lift I think a less aggressive lobe with a touch more lift will get you a lot of the same without the valvetrain issues I have.
#35
Update for those that care to follow:
Used this Powerhouse LS Trunnion Tool. Made breaking down the stock rockers super easy.
Beautiful CHE Precision Trunnion Kit
A touch of OCD for the installation
Rocker assemblies all ready to go
My first time doing a cam swap/valve spring swap. A little nervous but have been doing tons of reading and watching YouTube.
I used the compressed air method and it worked out fine. I had 2 instances where the valves started going down when I was compressing the springs. Just had to back off the spring compressor and tap the retainers with a rubber mallet. Finagling the locks was kind of a pain but I got into a groove on how to do it.
All done with the installation of the TSP .660" POLISHED Dual Spring Kit w/ PAC Valve Springs, Titanium Retainers, & PRC Integrated Seat/Seal
Next is to drain the radiator and power steering and start stripping the car to get to the cam. Planning to use this thread mostly for the tear down: https://www.corvetteforum.com/forums...full-pics.html
93Polo (05-19-2020)
#36
Photo dump from last night:
Stock cam ready to come out
My (our) first cam swap
Custom PatG spec'd cam
Going in with plenty of Amsoil assembly lube. Note: I should have drained the oil. I thought I could get away with lowering the pan with the car full of oil (t was still fresh!). I made a mess when the stock oil pump came out and it started to drip everywhere.
New cam in with ARP cam sprocket bolts and red Loctite 262
Notice the little Katech logo for the C5-R Timing Chain
Timing chain dampener (same as LS7 since I have the dry sump LS3)
Blue Katech oil pump in
Valvetrain eye candy
More eye candy
Top end almost complete
ATI Super Damper - biggest headache of whole job. I tried ATI's installation instructions of torquing to 230 lb ft and you're good to go. I didn't notice the damper wasn't seated all the way until I started to put the PS rack back in place. Also, I had to lower the rear of the car onto ramps to keep the engine from turning over. Ended up putting the stock bolt in and torquing to 240 lb ft to get balancer to seat then reinstalling ARP bolt at 235 lb ft. That was a workout.
Reassembly complete!
Katech belt tensioner
Just needs oil and coolant flush
First fill with this funnel and I think I like it. It locks in like the oil cap
Recheck and top off oil and coolant flush later today and tuning appointment this afternoon!
More eye candy
The following 4 users liked this post by Mugen1516:
#40
