C4 Corvette NASA Super Unlimited Build
#41
Idea -- Consider that if you add these REMFLEX header gaskets, they are not only the best ones in my opinion, but also they give you a little bit more clearance to work with as they are thick, and don't compress much. https://www.summitracing.com/parts/r...make/chevrolet
#42
What do you think about replacing the support rods forward of the cross member front ears, with a large plate of aluminum and welded tabs to bolt to the subframe ears, and tabs on the plate for the front frame support vertical rods... essentially creating a sub floor that's also the bottom of the radiator inlet duct, and would be lower than the OEM profile by a few inches... level with the bottom of the front cradle/crossmember? Asking as I'm in a similar position with my 1986 car, and that's what I've been thinking about quite a bit, although it would also be the aero package for me, and I have some large 1/8 and 3/16 alloy plates to utilize.
Also, have you considered mounting a dry sump tank in the back right rear portion? Curious about your thoughts... it's been weighing on my mind.
The tank in the rear I might do, I just would need a lot more hose. I have a spot on the front where I think I can make a 2.5 gallon 6 inch diameter tank fit. This weekend I want to take some more measurements and begin mocking it up (wife says she will spring for the oil reservoir).
#43
I was looking at where the heater blower goes… would need to go past the plastic fire wall a few inches so that’s some extra fab work, and some groups don’t allow such modification of the firewall. (I have a front half of a car to mock it up first, perhaps use it as a run stand.). Another/better option would be right rear next to a shorter fuel tank… I think hoses would be the easy part. Need to figure it out.
#44
#45
Heck of a build I have nothing to add other than I sure enjoy following this thread
#46
Yes love these custom build threads. I wonder how that C4 ZR1 with very long thread is doing.
#47
Originally Posted by chucknasty;[url=tel:1607286057
1607286057[/url]]Thats where I'm looking to install it. I already have a heavily customized aluminum firewall to give more space (some pictures above)
ZF Doc just dropped off the rear pan from a scrap 1993 car… what’s the wasted space underneath forward of the box, it doesn’t make sense to me.
#49
Originally Posted by chucknasty;[url=tel:1607309108
1607309108[/url]]What is the size of that reservoir?
#50
Updates:
Musclerods headers installed and worked
35mm front sway bar installed
Talking to RBD Racing in VA to handle remaining sheet metal work (tubular front frame, splitter, radiator mounts, shrouds, belly pan)
I should have pictures this weekend
BrianCunningham (01-08-2024)
#51
Dropped the car off to RBD racing on Friday. Rick is chopping the front end off and making a tubular one that bolts on. He will also build the splitter and all duct work to and from radiator with hood pin mounts for the hood to finally be pinned. Other stuff he's working on there: brake lines, reinforced rear spoiler mounts, maybe the lexan
#53
Really nice getting that radiator laid back!
#56
Any updates on this project!?👍
BrianCunningham (04-02-2024)
