Track Coolant use ?
Old 06-08-2019, 08:54 AM
c5racr1
c5racr1's Avatar
Default Track Coolant use ?
Just out of curiosity, what are you using for track coolant? I’m using water and water wetter, but I’m thinking i need to add something else due to the the different metals in my cooling system. I don’t want to get pitting. Thoughts?
Old 06-08-2019, 11:20 AM
fatbillybob
fatbillybob's Avatar
water and water wetter only! It can save you and the guys around you. Change the mix annually. Corrosion is not a problem in track cars.
Old 06-08-2019, 11:29 AM
SocalC5Z
SocalC5Z's Avatar
Use distilled water and Water Wetter if you're concerned about corrosion. Never use antifreeze on the track.
Old 06-09-2019, 12:40 PM
Dan H.
Dan H.'s Avatar
St. Jude Donor '17
Old 06-09-2019, 02:41 PM
Spaggs
Spaggs's Avatar
From what I understand about Distilled Water and Water Wetter is that they are for the "Track." In an ideal world where you have a dedicated track car, by all means use these two. If you have a dual purpose car where you are attending a car show one weekend and then a track event the next I would use the Antifreeze/Distilled Water. Most HPDE events will have a large percentage of drivers on Antifreeze/Distilled Water. Water Wetter is very helpful as a lubricant for your OEM Water Pump, but in reality the OEM stuff is manufactured to be used with Antifreeze/Distilled Water. If you are in the mode of a Pure Track vehicle, then you start logging how many hours/events your water pump has on it vs. just waiting for a leak. When you get to a predetermined hour/event count, you replace the water pump. At this point you should have a list of just about everything to be replace at a predetermined hour/event count.
Spaggs
Old 06-25-2019, 08:50 AM
NoradIV
NoradIV's Avatar
I am just using the standard 50/50 water/dexcool so I don't have to pull the water out of the block in the winter. Running stock C5 Z06 with Ron Davis radiator with integrated EoC. No heat issues.
Old 06-25-2019, 02:53 PM
67Ranger
67Ranger's Avatar
If it's a pure track car that wont see sub zero temperatures, water and water wetter should be good. If its a street car, depending on your climate, some mix of antifreeze and water.
Old 06-25-2019, 03:35 PM
dclafleur
dclafleur's Avatar
I always wonder what folks did about running water when they weren't at the track, when it's approaching the end of the season do you just drain it after every event? I've had a couple of off-season events where the temperature was below freezing overnight and part of the day and always found myself wondering that.
Old 06-25-2019, 03:40 PM
mgarfias
mgarfias's Avatar
DEI makes a water-wetter like thing that also has anticorrosion agents.
ETA: http://designengineering.com/radiator-relief/
Old 06-25-2019, 11:04 PM
BrunoTheMellow
Support Corvetteforum!
BrunoTheMellow's Avatar
Received 1,397 Likes on 1,000 Posts
20%/80% for my street / track c7 z51 and now c7 z06
To Track Coolant use ?
Quick Reply: Track Coolant use ?
