Delrin Bushing Install
#41
I assume you understand there are going to be a "bunch" of washers under that bone when you align it. Gap "might" be less then, but I really don't see how torquing the bone down changes that, I have done a few each of rubber/poly/delrin. Looks to me like one or both pieces of delrin needed to be a few thou thicker at those shoulders. Once again why I went poly, not being a wize azz, just sayin. Delrin needs to be hand fit.
Good luck.
Good luck.
#42
First, I haven't read all of the reply's in this post. But I hope that you've made progress.
I just recently installed two sets (two cars) of the Delrin / Aluminum kits in both upper and lower control arm bushings kits.
All of the aluminum machined parts were accurately machined.
If you look closely inside the the Hole in the control arms you will see that they are Ribbed. What I've heard over many years is that GM never intended these controls arms to be rebuilt.
I use a Brake Hone with Cutting oil very slowly and for a very short period. Then measure each control arm hole and fit them individually. You don't need more than a few Thousands Fit. Check with the Tech Support for their advice. All the kits that I've installed require drilling a hole and tapping the lower control arms for the Grease Zerks
Be certain to keep the individual components grouped, they are all "Match Fitted".
Even though the Control Arms are Aluminum as well as the Delrin Kits. The Aluminum parts in the Kits are anodized and therefore become an insulator. So I always use Anti-Seize for a lubricant, after cleaning all the surfaces with Acetone.
You will love the improvement. Hope some of these photos help out...
Michael
Michael
#43
Supporting Vendor
Michael
Michael
#45
Any thoughts on how I can get this bushing removed? It appears to have glued itself to one side of the arm and simply wont deform and press through. Apparently, the bushing extruded out one side and put pressure on this side while in the car, heating it up to be as hard as a rock and gluing it to that surface. I can't press it through the other way because it doesn't fit in my vice that way, and stacking stuff up in the 12-ton press has Darwin written all over it. This photo is after it has relaxed substantially. I pressed the hell out of it on my press.
I tried pressing it through, but it simply won't go. Afraid if I keep pressing it even harder it'll mess up the arm as it goes in. Not sure. Tried separating it with a screwdriver, but I'm just dinging up that surface. I'm sure some of you guys dealt with this. What did you do?
If there are no concerns it could possibly harm the control arm in any way, I'll press it until something gives. I haven't been that brave yet.
#46
I had a similar issue. I took a hacksaw and cut the side that was sticking out and then pressed through the other way with my vice. That seemed to take the pressure off and it went right out. YRMV.
#49
The edge of that bushing has a metal ring in it that holds it in. I used a pair of pliers to bend it out of the way. A few I had to rip the whole section off. It wasn't too difficult to do, just a little elbow grease.
#50
Supporting Vendor
#51
I did two whole sets of arms this way. Pretty easy once you get the hang of it. But like most of these projects, once you figure out how to do it, you're done and never have to do it again. I guess I was "lucky" that I got to do it a second time.
#52
Thanks for all the suggestions, guys! The job is pretty easy, it just seems I'm constantly fighting my tools. It seems like the easiest method would be to try and find a way to cut that lip off the one side so I can continue pressing it through like I was trying to do. Otherwise, use some of the tools that were recommended. Not sure I'll get any of those to work with that large lip covering the arms on the other side though. Will have to take a look at the tools and see which one will work.
#53
Also note that tools very similar to the ones Lane suggested above are available for free/loan at your local auto parts store.
#54
Well, that would certainly explain it. I'll see if I can pry it up enough without damaging that surface it's seated against so I can remove it. Now that I've put pressure onto it from trying to press it through, I've probably made it a bit more difficult for myself.
#55
I used my hacksaw last night on the side that's already pushed out, to try and cut that retainer off and push it out the other way. Sat there sawing for 10-15min and didn't really get anywhere. Same with my sawzall. If you guys made it through really easy, my blades must be pretty darn dull. Always fighting the tools...
Maybe I'll bring home an angle grinder and zip that thing off and find something to extend the press. Will figure something out. Thanks guys!
#56
Probably a little late for this, but get one of these, worth the $100 makes it way easier. I was able to press all mine out quick and easy using it and a small piece of pipe to extend the piston.
https://www.harborfreight.com/12-ton...ess-33497.html
#57
#58
That's the exact press I have. I was going to find a pipe to extend the ram as well. Just need to find something cut that retainer off on the inside so it'll fit through the arm easier. My sawzall and hacksaw didn't work, and my drill wont fit in there. The hacksaw/sawzall have seen a lot of work, so the blades are probably too dull.
I used a drill, too, to get the rings off. One of the stepped (pyramid shaped) metal hole cutting bits worked like a charm.
#59
I also have the stepped bits. They worked for the first 3 arms, but they simply wont cut any more. I have a drill bit now, but that drill won't fit on the inside of the arm with the bit attached. Just fighting silly tool issues, but I'll get it sorted.
#60
I did not read thru all the posts, I do have several videos on CA bushing remove/install. Not "that" hard. I am thinking maybe somewhere in your alignment method (of the tools) is where the issue is.
See below.
All these other ideas above seem pretty good.
See below.
