Auto Club Speedway (Fontana) advice
Old 02-14-2018, 01:10 PM
jimtway
jimtway's Avatar
One key advice for T3 braking. Stay at least 1 car width away from outside wall under braking. This gives you the best setup for late apexing T3 (needed to hit T4 correctly), and gives you some clearance to the wall incase the ABS gets squirrelly.
Old 02-14-2018, 01:15 PM
bellwilliam
bellwilliam's Avatar
Originally Posted by redtopz
it is funny that your top speed is at T3
that's some of best driving I've seen at ACS !!! Great job, Bill.
redtopz (02-16-2018)
Old 02-14-2018, 03:15 PM
Charley Hoyt
Charley Hoyt's Avatar
Billy Johnson has a good guide to ACS.
http://www.motoiq.com/MagazineArticl...eo-Inside.aspx
Nice laps in some stock C5Z's by bellwilliam and wtb-z!
I recently completed a race weekend at ACS. My C5 is built for GT2 and doesn't really hit much higher speeds than a stock C5Z but has a wing/splitter and many other upgrades. The most effective being my brakes; Essex AP Radicals which I give a ton of credit for helping me get pole position both days and first place overall both days including the GT1 cars in our group. In my car there is no lift for Turn 2, just full throttle from entering the oval to turn 3. You will only have to lift for Turn 2, not brake. If you haven't driven an oval it will take some time to get used to the extra grip. Here's a short vid on my qualifying laps:
All I can say about this is.... WOW! 150 through turn 2....incredible!
Charley
Old 02-14-2018, 03:18 PM
Charley Hoyt
Originally Posted by Moto One
Charley, I know about the track entrance protocol, this was video was done for a Chevy C7 intro event, when there were no other cars on track. But your right in staying below the line for the track entrance and low the shorter route. For me it really depends on the car and setup.
I figured you knew what you were doing. The video appeared to be instructional and in that case what you did was perfectly safe because you were obviously the only two cars on the track. I just wanted to point it out so newer people were aware of the danger for a normal track day.
Charley
Moto One (02-15-2018)
Old 02-15-2018, 10:16 AM
Moto One
Moto One's Avatar
I have to correct my turn numbering. What I called turn 2 is turn 3. I keep calling the hole bake turn 1, and not braking in to two sections.
Mark.
Old 02-15-2018, 12:24 PM
fatbillybob
fatbillybob's Avatar
Charley
Bill is a real talent in more than just his driving...
Old 02-16-2018, 10:13 AM
redtopz
redtopz's Avatar
Thanks guys! My car is not really setup for high speed tracks. If you've seen my car you know what I mean; it has a lot of drag with big panel gaps and open vents in the front and no effort has gone into making it streamlined for high speed. Another thing about my qual session is that I was scrubbing in new tires so I had to be careful not to overdrive the car and there was a head wind going down the main straight. Hoosiers maintain grip a lot longer if you properly scrub them in and gradually build heat into them, but you have to be careful not to slide them too much the first heat cycle. Then after 24 hours they are good to go .
Old 02-18-2018, 10:50 AM
kdm123
kdm123's Avatar
Thanks for all your advice! I drove ACS yesterday.
Well, it's been a long time since I've been scared in a car, but Turn 2---that $#@$ was scary, LOL! I wish I had another day to take a crack at it. I'll definitely have to come back as soon as I can.
Olitho (02-19-2018)
Old 02-19-2018, 02:17 AM
bellwilliam
I was there in my silver C5 Z06 also... which car were you in ?
Old 02-19-2018, 08:11 AM
kdm123
kdm123's Avatar
I was there in the blue Z06. I thought you were in the GT350 and the Super Miata? Did you bring your Z06 the next day? I could only attend Saturday.
Looks like early April is the next event at ACS. I'm going to do the whole weekend this time. Hope to see some of you guys out there!
Old 02-19-2018, 09:27 PM
bellwilliam
I brought the c5 z06 the next day. broke 1:50 in the afternoon.
Olitho (02-20-2018)
Old 02-19-2018, 10:47 PM
jd86L98
jd86L98's Avatar
https://www.youtube.com/watch?v=9lnez2BSccI
Saw you out there, you were moving!
bellwilliam (02-20-2018)
Old 02-20-2018, 01:11 AM
  #33
kdm123
kdm123's Avatar
[QUOTE=bellwilliam;1596628763]I brought the c5 z06 the next day. broke 1:50 in the afternoon."
Well now I'll definitely have to come back so I can try to beat your time, LOL! Yeah, a sub 1:50 was my goal, but my fastest was a 1:54. I need to get my @#$@ together in the slow, technical stuff, and I need to not wimp out in Turn 2. But I'm looking forward to the challenge next time.
Old 02-20-2018, 01:41 AM
  #34
bellwilliam
what mod do you have ? you have 595RS-RR ? the one lap tire. 54s is very good for that tire.
Old 02-20-2018, 12:44 PM
  #35
Olitho
Olitho's Avatar
BellWilliam is an awesome driver.
I can't wait for him to finish turning that car into a Spec Corvette. I am expecting a lot of podiums and tops steps for William.
Old 02-20-2018, 07:09 PM
  #36
TAK2TRK
TAK2TRK's Avatar
I was out there Saturday. First time in the Z06 at autoclub. Showed up a bit late and only got in 7 laps, but got into the 46s before the car was at 280 oil and had to call it. Going to need an oil cooler asap. I was in the Silver 2016 Z06 with the carbon hood.
Old 02-20-2018, 07:50 PM
  #37
bellwilliam
280F !! oil is just warming up !!
what tires were you on ?
To Auto Club Speedway (Fontana) advice
Old 02-20-2018, 07:59 PM
  #38
TAK2TRK
TAK2TRK's Avatar
What do you think is a safe high limit for the oil?
Tires were R7s with 3 prior BRP days on them + driving to and from OC to BRP. They felt ok, but not great.
Old 02-20-2018, 09:34 PM
  #39
crimlwC6
crimlwC6's Avatar
Bill is okay behind the wheel . What tranny/clutch do you have? You are able to shift faster than me and I'm surprised you hold second in a few of those corners instead of just coming out in 3rd...but you are better than me
Old 02-20-2018, 10:40 PM
  #40
bellwilliam
I was just kidding around. 300F is my limit for oil temp. I will start to back off at 300F, but it wouldn't bother me too much.
Quick Reply: Auto Club Speedway (Fontana) advice
