Brey Krause harness bar SCCA Solo legality
Received 2,061 Likes
Brey Krause harness bar SCCA Solo BS legality
I've been reading/receiving some conflicting information on it for stock class and looking for clarity for those that know, appreciate the insight.
Appears to me that the c6 bar is legal as shipped. The c5 bar is legal if you do not use the two bars that run down to the seat mount on the floor.
13.2.h
Pretty sure that the B-K is a truss-type, not a C-type.
13.2.h
"A horizontal “harness
bar” may be used as part of the installation hardware for allowed driver restraints provided it has no more than 2 attachment points to the chassis and is bolted at those locations. A C-type harness bar may also be used. It may have 4 bolted attachment points to the chassis (2 primary and 2 sup- porting connections to resist rotation). Truss-type harness bars with more than two (2) attachment points are not allowed.
Agreed it's a truss type, but seems like it'd be a safety issue if you didn't install though I'm going see if it rotates without them. I've reached out to Sam Strano with no response, if anyone has any other ideas I'm all ears. Have a week to cancel going to Nationals and would like to know for sure as I'm not wasting a trip without it when a BMW 1m in the class can run the same tire size as C5Z in AS (275/35r18 & 315/30r18), so need all the help I can get as my rears are the same size as his fronts and the thing isn't much heavier with more torque and better gearing.
I had a BK bar in my GS and had the same concerns. Before Dixie 2016 I wrote a letter for clarity. My specific question was not answered in time for Dixie but later in the year the rule was changed to allow truss type bars with two attachment points. Search through the fasttracks from last year.
I assume C5 BK bars are similar to C6's.
https://dk1xgl0d43mu1.cloudfront.net...pdf?1477062058
1. its only not legal if you get protested. (and to get protested, you have to be in the top three beating the expected normal winners, and protested by them).
2. a close look at any ones car can give you ammo (bet they have something illegal too).
I know because someone was going to protest my none stock **** ****. I found just on his car, modded seat (removed seat spring lower cushion) (weight reduction) metal sway bar links (should have been plastic links for his model year)
and he was so far down on time the officials called him on the protest " do you really think a shift **** gave him a 7 sec lead over you", and I was mid pack at best anyway. He ended up blowing his motor because he used a tech 2 to up his rev limiter (to much) causing valve train failure... Karma.
And that why I went from National tour/Nationals to doing track days.
Mark.
Mark.
Anyway, I can't think of anyone that would protest a B-K bar in either car for any class. The C5 version is useless without those legs and it is only a safety item. The B-K is very well known and well built.
Boony, you ran AS, didn't you? I was at Dixie in SSP with my B-K. The year before I had one in my C5, though I was in CAM-S.
And I wouldn't be worried about the 1M...
I pulled the lower braces and it doesn't move enough to be a concern. I don't expect to podium being it's my first trip to Nationals, but hope to trophy and would hate to loose it so looking to be prepared as best possible. I beat the 1Ms owner at last Sunday's event, but it's the co-driver that I'm almost certain will be on the podium as he's predicted to win. Thanks to all for the help, will see how things go soon enough. Just as excited to run Circuit of the Americas the week before!
Godspeed, Chris
Godspeed, Chris
Mark.
Mark.
I honestly wouldn't worry about it either. I can't imagine any of the guys at the top are going to think you beat them because you have a harness bar in the car. But if you're really worried why not just take it out and run with an aftermarket lap belt to hold you in place?
Godspeed, Chris
Godspeed, Chris
It is...
Mark.
Mark.
Shift ***** are legal in Street.
This was back in the day Super Stock.
To the OP, if you haven't been to Nationals before, don't put much stock into how you do at local events. I was the big fish in our small pond region and not bad at the National tour, and as noted, only mid pack at nat's. And only being a few tenths off the leaders is a mile there.
Kinda like being Valedictorian in High School, and then getting to Ivy League Collage where you just one of the students.
Watch learn, most of all have fun...
Then again you could be the man/gal/what ever. (not a slam, really)
