C5 Z06 2001-2004 Wheels sizes.
Old 05-22-2017, 11:30 PM
cagotzmann
cagotzmann's Avatar
Default C5 Z06 2001-2004 Wheels sizes.
So the factory wheels are
front 17 x 9.5
rear: 18 x 10.5
Can you run 18" all around for track use or do most of you find good enough tires in both 17 & 18" sizes.
There are no MICHELIN® Pilot® Sport Cup 2 tires in 17"
What are you C5 guys running for tires ?
Old 05-23-2017, 12:16 AM
Reggie Dunlop
Reggie Dunlop's Avatar
Many of us run 18s square. Search "18 square" or "18" square".
Old 05-23-2017, 06:47 AM
Dan H.
Dan H.'s Avatar
St. Jude Donor '17
The challenge can be finding tires that match for the two different size wheels. Many people will pick up a second pair of rear wheels and put them on the front. This allows you to rotate the tires or move them side to side to even out wear.
Sind this is a popular thing to do in the track world, the 18x10.5 wheels are sold quickly used and people get a decent buck for them. I'd advise skipping the hunt for used ones and just call Bob's house of wheels and order two new wheels. I've gone both routes and unless they fall in my lap I'll just buy new ones when I need more.
You have to scour the classifieds and CL to try to find them. When you do they sell quickly if your not the first to see them. The sellers get between 150-200 a wheel. And the wheels are 15 years old and you have no idea about their history. The first time you know they are true is when your tire is being mounted and balanced on them. Skip the unknown, skip dealing with people on CL, and skip the wait. Bob should give me a deal for this post!
If your going this route, hang onto those front 17's. Those are dirt cheap and could make a good rain wheel if you end up with a rain set. If your a DE guy they are fine, if you compete my guess is they are not ok. I don't compete so I'm not sure
Old 05-23-2017, 12:54 PM
moespeeds
moespeeds's Avatar
Goto 18 all around. You get longer tire life because you can rotate them however you'd like, and it really uncomplicates things.
Old 05-23-2017, 01:11 PM
SocalC5Z
SocalC5Z's Avatar
To echo what the others have written, the factory 18" X 10.5" C5Z wheels are well made and light weight. Running these "square" is the way to go to maximize tire wear and I find that the car really could use wider tires than the stock 9.5" wheels allow. I've just tried the Maxxis RC-1's in 275/35-18 and was very pleased with the wear and grip. Lots of guys run Nitto NT01's in 315 on the same wheels.
Old 05-23-2017, 11:25 PM
cagotzmann
cagotzmann's Avatar
So the factory rear wheel fits on the front ? or do I need a different wheel with a difference offset to use the 18" on the front. ?
Old 05-24-2017, 12:43 AM
SocalC5Z
SocalC5Z's Avatar
No, the rear C5Z 18 X 10.5 fits the front with zero changes, like it was designed for it.
Old 05-24-2017, 06:43 PM
YLO Z06
YLO Z06's Avatar
2023 C5 of the Year Finalist - Modified
Any ride height adjustments necessary when going to the 18x10.5 wheel up front? That wheel/tire combo is larger diameter than the stock 17x9.5 wheel/tire.
To C5 Z06 2001-2004 Wheels sizes.
Quick Reply: C5 Z06 2001-2004 Wheels sizes.
