Now Available - AMT Full Floating Rotors for C5 and C6 Base Corvettes
Old 10-04-2016, 01:54 PM
Mark@AMT Motorsport
Supporting Vendor
Mark@AMT Motorsport's Avatar
Default Now Available - AMT Full Floating Rotors for C5 and C6 Base Corvettes
AMT Motorsport Full Floating Brake Kits
AMT Motorsport is happy to announce the arrival of our first product - Full Floating Rotor Kits for all C5 and C6 Base Corvettes
These rotors will fit C5 and C6 Corvettes with stock calipers as well as aftermarket calipers that run the stock 325mm rotor size
These first 10 kits are available for $700 and FREE SHIPPING for the set. After this first run is sold on Corvette Forum the price will go to $800 a set. We believe there is not a better quality, more feature laden rotor setup at this price point.
To place an order please e-mail Mark@amtmotorsport.com or PM me on Corvette Forum.
Benefits of running a full floating rotor:
-Greatly improved rotor life
When I first started HPDE'ing the C5Z in stock form I would crack brand new Centric rotors in about 3 hours on track. I had to bring 2 spare rotors to every event I attended. The first time I went to a 2 day event and cracked all my rotors including the spares and had to miss part of the second day, I switched to the AP Racing caliper setup. Since moving to a 2 piece rotor I've never cracked a rotor and have gone as much as 2 seasons on a single set. Yes 2 piece rotors are far more expensive than $50 junk one piece rotors. If you love being under your car and switching out hot broken rotors all weekend long, then this product isn't for you. If you're sick of losing track time because of broken rotors, these are a solution.
-Greatly improved braking feel due to radial and axial float
These rotors float in both the radial direction (spinning direction, if you like) and the axial direction (away from the rotor hat). This allows the rotor to move freely within the caliper and eliminates all the vibration and pad knock back that occurs with a single piece rotor. Nasty vibration coming through your pedal and shaking your whole car around at 140+ MPH is unsettling. These rotor kits eliminate that vibration.
-Better Heat Dissipation
The 6061 aluminum hats keep the heat in the rotor where it belongs and out of your calipers, brake fluid, and wheel hubs. Heat destroys those components and the more heat you keep out of them the longer they'll last.
-Replacement Cost
Once the initial investment is made, replacement rings can be bought for $200 per side. Considering a set of rings will typically last a whole season, the money is quickly saved when you're not trashing $50 rotors every 2 days.
Please read below for more pictures and product details.
The heart of the kit is the rotor and we've used some of the best available - the DBA 5000. There are many superlatives used to describe these chunks of iron. Kangaroo Paw vanes do a good job of venting the rotor, the clamping surfaces are .400'' thick to hold a lot of heat and provide very long wearing discs, and their heat treatment process further resists warping and cracking. Bottom line is we used a single rotor for the entire season of racing and testing on the #265 C5Z (Full aero, Hoosier A7s, AP Calipers, 1.7Gs of braking) and the rotors look barely used. Replacement rings will be $200 each.
The rotors arrive at AMT with holes and not slots. We machine the slots in one of our Haas CNC mills. Each rotor is probed individually in the machine and in our custom fixture to make sure the slots are machined exactly in the center of the rotor.
The hats are machined in house from US-sourced 6061-T6 aluminum. The source of aluminum does matter as non-US material can often be riddled with cracks and pores in the material. The material used is of ASTM B221 spec which is the most common spec called out when we make critical components for the Defense and Aerospace industries. The hats are black anodized for corrosion resistance and laser engraved for sex appeal.
The rotors have hexes machined to accept the NAS bolts. This makes for easier assembly and disassembly using only one wrench, and it ensures the rotors can be used on stock C5 and C6 base calipers.
The bushings that ride in the rotor slots and allow the rotor to float radially are made from hardened 17-4PH stainless steel. It's important to use materials for the bushings that have less coefficient of thermal expansion then the rotor material. We've seen kits that come with only steel bushings (rust like crazy) or brass (wears too much and very dissimilar expansion coefficients) Our bushings will never rust and barely wear no matter how many rings you use up.
Close up of included hardware. NAS bolt, 17-4PH bushing, and NAS jam nut. Jam nuts are included with replacement rotors. The jam nuts are labeled as "one time use only." To put that to the test I tightened and removed the jam nuts half a dozen times throughout the season just to see if they'd ever loosen up. Happy to say they did not.
In addition to radial float these rotors also have .030'' of axial float. This allows the rotor to run more true within the caliper. The axial float helps greatly to reduce pad knock back, especially in stock calipers with stock hubs. When vibrations occur (driving over curbs as an example) and the rotors do not have axial float, the rotor disc vibrates from side to side within the caliper - spreading your pads in the caliper and making for a longer pedal and reduced brake pressure at the next braking zone. This is less of a problem in cars with upgraded hubs. There are no springs sold with these kits to reduce noise between hat and rotor. That said, I've been running these rotors without springs at all four corners and never heard any noise from the hat/rotor "rattle." Multi-thousand dollar rotor kits from Alcon and Brembo don't use anti-rattle springs and those are big boy race car parts. If you're looking to run these brakes on your street car we can assemble with anti-rattle springs for a small up charge. There is extra hardware and assembly associated with the anti-rattle springs.
Thanks all for looking. Please post up any questions you may have and I'll be happy to address them.
Old 10-04-2016, 03:05 PM
franman69
Support Corvetteforum!
franman69's Avatar
Mark.. make a set for Z51 size C6 please.....
Old 10-04-2016, 03:45 PM
Mark@AMT Motorsport
Supporting Vendor
You know I want to. Convince your non-Z51 compadres to scoop these up quickly and it'll make a better business case!
Old 10-04-2016, 04:47 PM
johnny c
johnny c's Avatar
please please please.
Old 10-05-2016, 09:32 AM
Mark@AMT Motorsport
Supporting Vendor
See above! Besides, you use Z51 rotors on that Miata?
Old 10-05-2016, 11:28 AM
RDnomorecobra
RDnomorecobra's Avatar
4 rotors or just front 2 ?
Old 10-05-2016, 11:50 AM
Mark@AMT Motorsport
Supporting Vendor
Just the front 2. I use an AP caliper setup in the rear as well and these rotors do work back there. I don't think the stock calipers would fit the thickness of these rotors, even if I did make a relocation bracket. I'll check on that today. You'd also lose the parking brake, which matters little to race cars but may matter a lot to street cars.
Old 10-11-2016, 11:58 AM
Mark@AMT Motorsport
Supporting Vendor
Shipping rotors out today! Please let me know if anyone has any product or ordering questions!
Old 10-27-2016, 03:46 PM
Mark@AMT Motorsport
Supporting Vendor
Another set getting cleaned up and boxed for shipping. Thanks all for the support!
And yes, that white stuff outside my office window is snow...
Old 11-08-2016, 09:19 PM
stevensa
stevensa's Avatar
Just installed my first set of AMT 2-piece rotors. Very pleased with the overall quality and fit/finish of the product. Very excited to get these out on the track!
The following 2 users liked this post by stevensa:
Mark@AMT Motorsport (11-09-2016), StreetSpeed (11-08-2016)
Old 11-09-2016, 10:09 AM
Mark@AMT Motorsport
Supporting Vendor
Lookin' good! Thanks for the business. Please let me know if you have any other questions.
Old 01-09-2017, 10:55 PM
deepcj7
deepcj7's Avatar
Still have a pair for $700?
Old 01-10-2017, 06:27 AM
Mark@AMT Motorsport
Supporting Vendor
We do indeed! If you want them PM me your email and I can send you an invoice.
Old 02-15-2017, 03:25 PM
Mark@AMT Motorsport
Supporting Vendor
Just stole a shot from a fellow using these on the rear with a very purdy PFC caliper. In stock and still $700 shipping included for CF Forum members. Thanks for looking. PM me or post up if I can answer any questions.
Old 02-15-2017, 05:48 PM
Dubstep Shep
Dubstep Shep's Avatar
Any chance of getting these for the C6Z caliper sizes?
Old 02-15-2017, 06:15 PM
Mark@AMT Motorsport
Supporting Vendor
Let me do a little digging on that. I now have wholesale pricing access to a few different brake rotor manufacturers so let me see if there is some quality stuff I can buy in smaller quantities without it costing a fortune.
The following 2 users liked this post by Mark@AMT Motorsport:
Dubstep Shep (02-17-2017), ferrmaro (02-17-2017)
Old 02-22-2017, 11:42 AM
Mark@AMT Motorsport
Supporting Vendor
2 sets headed out today for CF Members. Still $700 shipped for the set. Thanks all for the continued support!
To Now Available - AMT Full Floating Rotors for C5 and C6 Base Corvettes
Old 08-09-2017, 02:16 PM
Rob Willis
Rob Willis's Avatar
Any chance of C7 offerings?
Old 08-09-2017, 02:19 PM
Mark@AMT Motorsport
Supporting Vendor
Not at this time, I'm afraid. I'll re-check with my supplier if there are other rotor blanks sizes available, but when we did these they only had these blanks in C5 and C6 base and didn't intend to get larger sizes any time soon.
These things sure are badass though, if I may say so myself. Going on 2 seasons of racing and they've got plenty of life in them.
Old 07-07-2021, 12:28 AM
Function Racer
Function Racer's Avatar
Are these still available? Still a discount/free shipping to cf customers?
Quick Reply: Now Available - AMT Full Floating Rotors for C5 and C6 Base Corvettes
