CNC Ported Cylinder Head Sale
Former Vendor
MTI Racing has CNC Ported cylinder heads for your high performance application. Weather you are going naturally aspirated or forced induction we have a ported head for you.
MTI Racing is running an in house installation sale on our ported cylinder heads. MTI Racing ported heads retail price range from $1895 to $2700 depending on application. MTI Racing is selling ported heads for $1000 plus installation, price will vary depending on vehicle. You are literally saving $900 to $1700 dollars for the cnc ported cylinder heads. These heads have been cnc ported, 5 angle valve job, and hand finishing of valve job. MTI Racing cylinder heads are assembled with dual valve spring, titanium retainers, chromoly spring locators, new locks, viton valve stem seals, .650 lift max with stock GM valves.
Please call for available heads 770-919-7774
LS6, LS2, LS7, LS3, L99, LSA, LS9
For the past 20 years MTI Racing has been at the cutting edge of LS performance and our cylinder head program is no different. The LS cylinder heads flow darn good out of the box but there are huge improvements that can be made during the porting process that will increase power and torque. What does this mean to the end user, exceptional performance and ear to ear grins all around.
CNC cylinder head porting not only creates better flowing heads which in turm create more power but also correct casting flaws and core shift within the cylinder head casting. What does this mean, it means all the ports, exhaust and intake will be identical and perform the same. Look at it this way, if your cam lobes, intake runners, and valve sizes are consistent then your cylinder head ports need to be consistent also.
MTI Racing does all of it's head porting in house utilizing the best porting machinary in the industry, the Deckel Maho DMU-80 5-axis VMC, Boston Digital 505 5-axis VMC, and Newen Epoc 4 Axis macine for the Valve Jobs. When some people think of porting cylinder heads they think of porting the intake and exhaust ports as large as possible to make the most usable power possible, fact is porting cylinder heads takes a lot of time, testing, and precision machining to get it right. In a racing application the previous statement is some what true but when it comes to porting cylinder heads for street use maintaining port velocity is crucial for proper torque levels. Achieving this requires experience and proper equipment to get it right. Race cars are not so dependent on torque as they tend to operate at a much higher rpm level where horsepower is the name of the game, street cars operate at a much lower rpm range which relies heavily on torque.
MTI Racing can also work with each customer to meet any specific needs they may require. This gives the customer flexibility in the components that are used to assemble the heads and change chamber size if needed. We also offer head repair service. If you have a cracked or overheated head give us a call.
Features and benefits of CNC ported heads
* Full CNC porting of intake and exhaust ports
* Proper 5 angle valve job for optimal airflow
* Hand finishing of valve job into the port
* Surface cylinder head for proper head installation
* Machine all valves for proper seating
* Cylinder heads will be ready to install out of the box
I have an LS3 with bolt ons, a cam, and a custom tune, sitting at around 455 rwhp Dynojet. What sort of improvements can I expect with utilizing your heads and a matching tune?
Would I get more gain just buying aftermarket heads? How much more for how much more money if so?
Thanks.
Thanks.
