Quick question re Raybestos ST 43 compounds
I have an event coming up about 4 hours drive from home with a lot of track time. I have new bedded in Raybestos ST43 pads up front bedded in to some street conditioned newish rotors.
I can change rotors and pads at the track but would prefer not to unless I have to (I always have spares). Any issues with driving these pads this sort of distance considering they will be cold all the way.
Nah, don't worry about covering the brake ducts. Even doing that, you won't get them up to temp. on the street anyway. You won't notice any wear at all driving them a few hundred miles on the street.
They'll be fine on the street. You may not reach the optimal temp range, but they'll at least be in the functional temp range, which is wide on the ST43. I drove mine on the street a good bit without significant rotor or pad wear, and the bedding seemed to hold up fine despite the cool temps.
Like others have said, you'll be fine.
The thing I don't get is the pads didn't add significant noise vs. stock pads. Are they louder? yes, but a few reviews on here made them out to be the banshee of all brake pads when used on the street.
They can be banshees........right now my pads are pretty quiet, but I have not found a consistent pattern of noisy vs quiet.......just be prepared for those looks from other drivers when you pull up next to them as your brakes are literally screaming.
Since then I have completed two 10/10ths track days at NCM. Also maybe 75 street miles and still pretty quiet.
A guy next to me at the track event was on Hawk DTC 60s and they were quite a bit louder when he was coming to a stop than I've ever been.
Does it require a certain number of miles? I bought ST43 front and rear pads with new Centric rotors (front and rear).
I have been doing this long enough to have experienced Hawk Blue pads (not sure anyone uses these anymore). Wonderful feel and modulation but terrible release characteristics.
You COULD drive them on the streets but the pads were so abrasive they worked like mini-lathes on the rotors. Made the rotors nice and smooth but way too thin in no time and left a mess on the driveway the next time you washed the car.
No such issue with the Carbotechs I have used for the past 2 seasons but the Raybestos pads are new to me and I gather a bit more aggressive on the rotors.
Nope, Raybestos ST43 pads are rotor-friendly........been using them for over 8 years, first on my Mustang, now on my C6z.
Thanks.
I'm considering using ST-43s on my weekend only (spirited driving and occasional track car) with Giro Disc 2pc rotors and wanted to know how many miles you were getting with those pads out of your rotors? I'm more concerned about rotor wear since the 2pc replacements are pricey.
Thanks.
Thanks.
Do you only put the pads on at the track or do you also get some street use out of them? Wondering if an 80% to 20% split of street to track driving will eat the rotors (Giro Disc 2 piece) in under 20k miles.
The car is a dedicated racecar now, but when I first built it I drove it on the street with these pads a good bit and there wasn't any visible wear. They're noisy, but don't seem to mind lower street temps for function or rotor wear, pad wear was fine on the street too.
