Katech Titanium 12x1.5mm 12pt lug nuts. Finally, an affordable, quality Ti lug nut!
Old 06-26-2015, 09:50 AM
Katech_Zach
Premium Supporting Vendor
Katech_Zach's Avatar
C7 of Year Finalist (track prepared) 2019
Default Katech Titanium 12x1.5mm 12pt lug nuts. Finally, an affordable, quality Ti lug nut!
In the past, racers and weight nuts have paid up to $500 for titanium lug nuts. We are now offering these high quality pieces at a very affordable price of $6.99 each.
http://store.katechengines.com/titan...15mm-p490.aspx
__________________
Contact:
(e) zach@katechengines.com
Old 06-28-2015, 01:53 AM
db2xpert
db2xpert's Avatar
How much lighter are they on a per wheel basis?
Old 06-29-2015, 08:15 AM
Katech_Zach
170g/wheel lighter
Old 06-29-2015, 09:52 AM
LateBreak
LateBreak's Avatar
Wowzer, you'll sell a buttload of these.
Old 08-07-2015, 08:52 AM
Katech_Zach
Lug nuts are now available in carbon black.
-SOLD INDIVIDUALLY
-16 grams each
Not just any black lug nuts. These are coated with a high tech, proprietary Diamond-Like Alloy coating utilizing the latest coating technology to provide a very durable surface.
-Very low coefficient of friction
-High mechanical hardness (2600 Hv)
-Coating thickness: 1-5 microns
-Surface roughnes: Ra~.03um, Rz~.2um
http://store.katechengines.com/titan...lack-p510.aspx
Old 08-07-2015, 12:24 PM
mdaniel
mdaniel's Avatar
Are these compatible with extended DRM or ARP studs?
Old 08-07-2015, 12:51 PM
Katech_Zach
yes
Old 08-07-2015, 02:12 PM
mdaniel
mdaniel's Avatar
Ordered.
Can you confirm that these require a 17mm 12-point socket?
Old 08-07-2015, 02:34 PM
froggy47
froggy47's Avatar
Ordered.
China? Hey, somebody has to ask.
Old 08-07-2015, 02:35 PM
Katech_Zach
Ordered.
Correct.
Katech_Zach
Originally Posted by froggy47
China?
Yes.
Old 08-07-2015, 02:42 PM
fruitsalad
fruitsalad's Avatar
How would the black finish hold up with frequent use of an impact?
Old 08-07-2015, 02:50 PM
Katech_Zach
Based on the properties of the coating we are very confident they will hold up well.
Old 08-07-2015, 03:39 PM
mgarfias
mgarfias's Avatar
Jason -
Any change in target torque values w/DLC coating?
Old 08-07-2015, 05:10 PM
StreetSpeed
StreetSpeed's Avatar
Yes.
Well that explains that (as well as the vibrations in the threads)! If you're selling them for $7 you must be buying them for $2ish. A $2 Chinese lug nut that keeps the wheels on my car scares me.
Old 08-07-2015, 05:28 PM
Werks
Werks's Avatar
Have you ever seen Katech put out any type of sub-par, low quality product before....ever???
Old 08-07-2015, 05:34 PM
Katech_Zach
Originally Posted by mgarfias
Jason -
No
You're making assumptions. You don't know what these cost us, the material used, or how much we've scrutinized them before putting them to market. They've passed our muster.
How do you know your current lug nuts are not made in China?
Thank you.
To Katech Titanium 12x1.5mm 12pt lug nuts. Finally, an affordable, quality Ti lug nut!
Old 08-07-2015, 06:07 PM
StreetSpeed
I don't want to blow up your spot - sorry about that. I own a CNC machine shop and have done lots of work with Chinese parts and Chinese material. Best of luck.
Old 08-07-2015, 06:53 PM
mgarfias
mgarfias's Avatar
No
So, you say they have a "very low coefficient of friction", i.e.: lubricity. Lubing threads require a change in target torque. So... Which is it?
Also, why are the threads cut instead of formed?
Old 08-07-2015, 08:50 PM
froggy47
froggy47's Avatar
I don't necessarily disparage every part made in China, just want to know what I am putting on my car.
I have been buying the cheap steel ones & tossing them every year replacing with new cheap steel ones.
ARP studs seem to last many seasons and I an VERY CAREFUL how they (nuts) go off/on.
So if I spring for these will they go for 2 - 3 years?
If, yes, then it could make sense for me.
Any testing?
My own personal testing on the cheap steel ones is 2 years max. This is assuming you change your wheels a lot, racer, not the guy who keeps the same wheels on his car until his tires wear out.
So testing as to durability, not how strong a brand new one is "one time"?
BTW Men's Health just published a small article listing Corvette (and F150) as two of the top 4 vehicles with the most USA made parts content.
Quick Reply: Katech Titanium 12x1.5mm 12pt lug nuts. Finally, an affordable, quality Ti lug nut!
