aluminum extension ramps for trailer
Old 05-25-2015, 04:16 PM
Chets LS3
Chets LS3's Avatar
Default aluminum extension ramps for trailer
basically like the above video. I need approximately 3 foot aluminum extension ramps.
I have a 18 ft ATC trailer, the way the ramps are race ramps aren't going to do the trick. any advice
Old 05-25-2015, 05:09 PM
fcarga
fcarga's Avatar
Call Pit Pal; they will/can make what you need.
Old 05-25-2015, 05:30 PM
emptnest
emptnest's Avatar
Default Made my own extensions
Less than $25, and assembled in stackable components, none weighing more than 25 lbs ea. Works like a charm!
Old 05-25-2015, 07:24 PM
0Fred@ReverseLogic
Former Vendor
Fred@ReverseLogic's Avatar
Default Race Ramps RR-SPR
Race Ramps introduced a heavy duty shop ramp last Fall that would probably work for your application.
http://www.reverselogic.us/shop.html...mps/p/45319603
Old 05-25-2015, 11:00 PM
Chets LS3
Chets LS3's Avatar
Problem with race ramps is; the act ramps have a sharp decline on the last 8-9 inches instead of a blunt edge. My car needs something in that gap as that incline is too much.
Old 05-25-2015, 11:50 PM
JerryTX
JerryTX's Avatar
Please try typing that again or show a picture, that didn't make any sense?
Old 05-26-2015, 12:08 AM
Chets LS3
Chets LS3's Avatar
http://www.aluminumtrailer.com/admin/flatgallery/galleries/42/13_atc_open_car_hauler.jpg
Let's try this link to the picture. The ends of the ramps are not blunt and squared off. The decline rapidly to make it easier for cars to climb onto the ramp. Just too much incline for the corvette
Old 05-26-2015, 09:08 AM
0Fred@ReverseLogic
Former Vendor
The Race Ramps shop ramps have a 1.5" deep step which is less than the 2" to 3" deep step on most of the other Race Ramps trailer ramps. If you provide the following dimension for the trailer I will send you a graph of the car climbing the ramps to confirm the amount of clearance you will have at the transition point between the Race Ramps and existing trailer ramps.
1) Trailer deck height:
2) Existing ramp length:
3) Existing ramp thickness:
4) Length of angled section at end of existing ramp:
5) Thickness at very tip of ramp:
Old 05-26-2015, 09:35 AM
JerryTX
JerryTX's Avatar
Based on that image Fred at Reverse Logic can definitely help you. I've bought some great stuff from him in the past.
Old 05-26-2015, 01:15 PM
Chets LS3
Chets LS3's Avatar
If I would have seen this sooner I would have given that a shot. I found someone local to build a set of jumper aluminum ramps and already brought my trailer there this morning. Didn't think I would have found someone that quickly to build some.
Old 06-02-2015, 02:39 PM
shotchkiss
shotchkiss's Avatar
I have a pair of these over lay ramps I use with my ATC ramps, the 5' ones that came with it are just a bit short
http://www.discountramps.com/trailer...60-00-LAYOVER/
They just lay on top of the existing ramps and lengthen them as well as reduce the breakover angle.
Old 06-02-2015, 09:17 PM
yooper
Support Corvetteforum!
yooper's Avatar
Old 06-03-2015, 10:15 PM
tytek
Gasoline Addict
tytek's Avatar
I use these Race Ramps that I got on Amazon (they had a 10% off coupon in Nov '14). They work great for my lowered on coilovers C5 track car, and my '80 C3. They are very durable and super light. I made my own ramps out of 2x8 wood, and they were way too heavy to fight with, so I bit the bullet and spent almost $300 on the Race Ramps. Very pleased with the purchase. They don't slip when under the trailer ramps, due to their construction, which is an added bonus, and fit well into the trunk of my tow vehicle (Nissan Armada).
I know this doesn't apply in your case, but others on here may find it valuable.
Amazon.com: Race Ramps RR-TR-8 8" Trailer Ramp: Inc. Brute Industries: Automotive Amazon.com: Race Ramps RR-TR-8 8" Trailer Ramp: Inc. Brute Industries: Automotive
Old 06-04-2015, 02:13 AM
Chets LS3
Chets LS3's Avatar
I will post some pics of my 36 alum extensions when I get a chance just got back from the track this evening.
Old 06-04-2015, 06:23 PM
FASTFATBOY
FASTFATBOY's Avatar
$35
Old 06-04-2015, 08:27 PM
emptnest
emptnest's Avatar
Default I'm impressed.
Originally Posted by FASTFATBOY
$35
👍 just used mine 5 minutes ago. Easy as pie.
To aluminum extension ramps for trailer
Quick Reply: aluminum extension ramps for trailer
