Front Bumper Thickness
I've been planning on making my own front tow hook. Anybody know the thickness of the front metal bumper so I get the right sized rivet nut?
I used rivnuts before in my old Jeep and they worked, but it was for something that saw much less stress, so I may decide to listen and just go with a backing nut.
Food for thought: Ever seen how hard it is to pull a car out of a gravel trap? How about when the brakes are locked up and all for sticky Hoosiers are sliding on the ground as the tow truck winches the car up on the rollback?
I have seen both... and I am not sure a rivnut would live up to it.
Yup.
My 1/4" steel toe hook got bent up when my PCM died, and that was with 4 rolling wheels, towed from grass and and then towed around one turn.
For the mount, I'd weld nuts to a sizable plate and weld that to the bumper thing, then fasten the tow hook to that, keeping in mind that the toe hook may get twisted and abuse some body panels.
I saw an aluminum tow hook on a BMW race car that had to be towed (again, with 4 rolling wheels) - it was fastened to the unibody equivalent of a frame rail - after the tow the "frame rail" was bent and the tow hook was toast.
Thanks for the advice guys.
My idea was to bend the rear of the tow hook 90 degrees and bolt to the back side of the bumper so the force was pulling into the back of the bumper instead just on the bolts underneath.
Of course... I guess I could also just forgo all of that and weld the hook to the frame.
