Supercharger, turbo or cam?
So i have a C6 with an LS3. I use it almost exclusively for auto x, and trying to get into track as well. Im going to get a cam, i also want to get a supercharger or turbo. but im afraid it would give it too much power and make it even harder to control... I was wondering if anyone here has any experience running auto cross with a turbo or supercharger?
I have a supercharged C6 which I have been using and my plan over the winter is to return it to NA. The power makes if harder to learn, control and not needed. The worst part is the higher engine temps which will eventually lead to engine failure somewhere. NA cars run hot so add 50% to a FI car.
Not sure of your skill level but unless your advanced I would leave the FI alone. When my friends ask "how did your car do" my response is "the right driver would lap me in my V6 4 door caddy and probably have more fun doing it"
My opinion
thx edge, you pretty much confirmed what i was afraid would happen its to bad really, a supercharger sounds so good on an LS. and thx Brian, that sounds like a good alternative
I started out tracking with a sc Z06. It was a lot of work dealing with cooling, belt slip etc. Unfortunately, the way sc works, you don't get to use all that hp except on straights - but it sure is fun though. When mine blew, I repl with forged H/C/I and it has a lot more usable hp all the way around the track. And yeah, it is faster down the straights also. Gas mileage is not as good on the streets, but, I didn't buy it for gas mileage. HTH.
NA for sure. I don't think a dry sump is needed for autocross.
