Wheel alignment for DD/Track car
First, I understand there is no good "dual use" setting for street and track. Given that, I have and '03 Coupe that I HPDE ~8 times a year.
The car has first generation Pfadt coilovers, Z06 sway bars (w/ poly bushings). Tires are brand new Hankook Ventus Rs3's.
I found the Pfadt Alignment sheet. I am considering using the "Performance Street - Track use with Street Tires" section.
Anyone think I should be setting it to something else? I'm an alignment noob. All I know is that more neg. camber will help me turn in more easily. I have heard that more rear toe-in will stop the back end of the car from the slight trammeling that happens on the long, off-camber, slightly turning, back straight at PIR.
All opinions welcome.
St. Jude Donor '15
You might see some inside tire wear over time if you daily drive. Actually more negative toe in the front will have better turn in on turns. Negative camber allows more tire footprint to be applied when turning.
For your usage I'd look at around -1.6* Front Camber, -1.1* rear camber. 0 Total Toe front, ~1/16" Total Toe in for the rear.
That will be a nice compromise with street tires. If you go to an R compound tire at the track, then you'll need more negative camber or you'll chew the outside edges off of them.
I ran though a set of 285/18 RS3s on my Z06 that were both street tires and track tires. -2* front camber, -1* rear camber ended up with reasonably even wear. The rear scrubbed the outside of the tire a bit. The RS3 is pretty soft and seems to need a lot of camber to wear evenly.
Actually, more negative camber (to a point) maintains grip during cornering. Toe out in the front helps with turn in. Toe out in the rear will lead to significant oversteer, so you want a touch of toe in.
Dog
Received 8,919 Likes
Bill
If you have to travel >100 miles or so for an event and don't have means to bring extra wheels, is driving there on an aggressive alignment with so much camber okay or will it ruin tires too quickly?
After trying several setups, including many changes from street to track and back which was a total pain in the butt, I totally agree with 96GS#007's advice. Those numbers will provide decent wear on the street with decent performance on the track. That's about as good a compromise setting as possible.
Dog
Dog
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Now as they said above, camber can be more easily locked in to a point and not effect tire wear by a huge amount, especially if you are street driving and track driving on the same set of tires. Point being they are not going to last 50k miles anyway.
One cool tip on the C5/6 cars. Bring a 13mm and a 7/8" wrench with you (if I remember right) and you can make simple toe changes at the track as long as you keep track of how you move it. You will notice on the toe links there is a hex portion of the bar. One flat (not turn), but one flat change will result in a 1/16" toe change. So if you want to do some simple changes your self, just document what you do...you can do some adjustments at the track.
For Street use...100% agree with that statement. Toe destroys tires in a heartbeat but can also make or break the feel of a car on track.
I would agree with that statement as a good starting point. Keep an eye on your tires and see what your car, your driving style, and the tracks you are on like. Each track can vary a bit so there is not one be all end all setting to use, but there are some good starting points.
Again...good point..not only does the track vary with what it wants for alignment, so do tires.
What kind of mileage / how many track days did you get with this alignment? I'm going to RS-3/RE-11 or something comparable and I would like a more aggressive alignment, but not at the expense of considerable tire wear. This is primarily a daily driver with a little fun at the track for me - I have other cars for racing / TT.
Thanks.
I went with a Camber kit from LG, I just move 4 washers per wheel before track day and then move them back after the track day when I swap my street tires back on. Then as Anthony mentioned you can just adjust the toe by turning them a couple of flats, once you have it set.
Thank you
