School me on sway bars
The easy part is bolting the sway bar on the car. The hard part is knowing the best way to adjust it.
Can you tell if your car is oversteering or understeering on corner entry?
Are you taking tire temps.
You answer yes to both questions then by all means get adjustable sway bars. If you answer no to the questions then put your Visa card away. You don't need adjustable sway bars.
Anytime something is adjustable you have a chance of making things worse.
Here's an article I wrote a few years back on sway bars. It's mainly C4 but the basics apply to any car.
A Trans Am sway bar
Richard Newton
A Trans Am sway bar
Richard Newton
run the hose from one location to another and put some water inside the hose
measure how high the water is from the floor in the center of the spot you will have your pad sitting on -- doesn't matter how much water, just relative difference
do that cross wise and F to R wise and side to side wise and you will figure out that one spot is highest
then shim the other three locations using 1/8" floor tiles from Lowe's
simple and easy to do
clear flexible plastic tubing
comes in a roll
I used 1/4" stuff
to measure water height off floor, use a rigid ruler like a kids 12" school ruler and tape the tubing on if you like
takes two people, really easy
Just went to Strano's website, the Hotchkiss front stiffness quoted on his website states 115% stiffer than the Z-51 bar, seems to me it should be closer to the JOC level for relative rate which would also change the front/rear bias to that of the T-1 or JOC selections.
Based on the chart below, it seems like Hotchkis front with C6 Z06 factory rear bar would be similar to Hotchkis front/Hotchkis rear in middle setting. Wondering if this is the case for ZR1 front with C6 Z06 rear.
