Run with TPMS in your track wheels??
Just like the title states...Do you have them in your track wheels, or if you drive to the track on stock wheels and swap at the track, do you have them in the track wheels?
Thanks!
Ron
Thanks!
Ron
I have them in my track wheels as well as the reset tool.
BTW - since we no longer have a C6 GS/Z06 they are doing me no good! LOL...I don't believe they will fit on the C7 Z51...so, I've got a set of LG Motorsports C6Z06 wheels and MPSC with TPMS ready to go for anyone interested...I'd guess there is about 50% tread left...need to actually measure though.
Former Vendor
This handy device will allow you to plug into the body control module of your Corvette and completely remove the tire pressure monitoring system with no ill effects to the car. Great for road racers and drag racers that have been plagued by tire pressure sensor issues for years. No more will you have to face those dreaded error messages or bothered by the computer when you install your track wheels and tires.
This will also allow you to start the car with Active Handling and Traction Control completely turned off so you don't have to reach down and hit the button if you happen to kill the car before a run. Your TC button does still work so you can turn those systems back on even with the box plugged in and running.
I run the sensors in my track wheels as well but instead of a reset tool I just cloned my street wheel sensors and so the track wheels match them, all I have to do is swap the wheels and I am ready to go. The car doesn't even know it has occurred.
I have my TPMS sensors in a pressurized container that mounts in the rear of the car. One 3-4" piece of 3" PVC and two end caps. Simple but effective.
Jim
Jim
I've seen several posts stating that this does not work since there is not enough motion to prevent them from going into sleep mode. You seem to have found a way around this......what's the secret? AND are you driving a C5 or C6?
Jim
Received 8,917 Likes
Well, maybe I've not driven it enough to see this problem. The car is a race prepared 2006 C6Z. I have an electrical kill switch that completely kills the power to the car and does reset the TPMS to all zeros. I use the kill switch at the end of the event to prevent the battery from becoming discharged. At the beginning of each event, I just reprogram the sensors. So it works for me but may not be viable for a combo street/track car.
Jim
Jim
Being an 06 your car probably will run an hour before it misses the sensors. My car is an 08 which can go about a half hour before noticing the sensors aren't broadcasting. When I tried installing sensors in a cannister everything went fine until I hit the half hour mark on track. At that point the car noticed the sensors weren't broadcasting fast enough and put me in 55 mph mode. If I let the car sit for an hour it would be happy for another half hour. You probably can do just as well taking the cannister out of the car and letting it sit in the garage or car trailer next to the car.
Bill
Jim,
Bill
Bill
I have an '07Z and I believe it can go 20 or 25 minutes before it starts complaining.
Jim,
Bill
Bill
Thanks for the info. I don't have much data on this car; I've only done five track events with it so far. At the first event, the car would not turn - massive understeer, but was perfectly happy going 150 on the straights. I discussed this with Aaron Pfadt and he told me that the problem was that I was using the kill switch in between track sessions and that was resetting the TMPS sensors to zeros. I was being overly protective of my tiny battery. No problems since then and this makes perfect sense with what you've said. The maximum session time is 40 minutes and there is over an hour between sessions.
As we have discussed before, I'm disconnecting the Active Handling steering wheel sensor before any more track time and that will also disable the TMPS.
So the canister solution has worked well for me in my particular situation but is not a solution for everybody.
Jim
I run sensors in all my wheels and just reset the TPMS based on whatever combo I have on at the time... (current run 3 different sets of rims/tires, HPDE, autox, and Street)
I'm curious why folks aren't running with the steering sensor pulled? I have no TPMS in my track wheels, I have pulled my steering sensor and run with TC and AH off - am I missing something here????
My car is driven on streets as well as track, so I feel the need for the nannies when not on the track.
Can you describe how it is turned on/off when the steering sensor is pulled? Do you still use the TC/AH/Comp button? Is Comp Mode still available? Can you turn everything off?
I run with the steering sensor plug unconnected as well and can vouch for it's effectiveness. No TPMS in any of my wheels and TC works fine. All modes are still available except that the data logger can't get a steering angle reading. Mind you, the LG product is an impressive solution too. Just wasn't around when I first disconnected my steering sensor.
