Need Advice: 75 Series Battery at 30lbs or 78 Series at 39lbs?
Hey all, normally I would never add weight to the car that wasn't necessary, but I decided to replace the battery in preparation for a slightly higher SCR motor I am putting together in the coming months. I've heard a few 11.25:1 motors at startup and the starters sound like they turn a bit slow. Also, the O'Reilly brand "Super Start" 75 series battery that was in the car (date marked 2012) seemed quite weak. If I left the radio on for 20 mins, the car barely wanted to start. The original battery can be seen here:
http://www.oreillyauto.com/site/c/de...0423&ppt=C0005
So I replaced the OE size Z06 battery (75 series) with the larger 78 series battery found in all 97-99 C5's, this is the one I chose:
The old 75 series had a CCA of 650amps while the new 78 series has a CCA of 850amps! Car starts much quicker now, but I weighed the new battery and it's 39 lbs while the old battery was only 30lbs. This has me quite distraught, as I have corner scaled the car and I'm concerned about adding 9lbs at a pretty high point in the car.
Any advice?
The other battery I'm considering is the 78 series Super Start Premium with a CCA of 700amps, which only weighs 24lbs!
Any advice?
Any advice?
Any advice?
