oil temp via OBDII - '03 c5z06
Old 05-19-2014, 09:13 PM
RDnomorecobra
RDnomorecobra's Avatar
Default oil temp via OBDII - '03 c5z06
I am using one of those mini blue ELM327 bluetooth OBD readers with my Android and RaceRender software to assemble track videos. I can get tach, water temp, intake air temp, throttle position, but can't seem to get oil temp. I don't know if my model/year doesn't send it across, or this chinese made reader doesn't pick it up or what. Anyone know any tricks?
Old 05-19-2014, 09:14 PM
RDnomorecobra
Old 05-19-2014, 10:06 PM
lefrog
lefrog's Avatar
Most readers can't pick it up. Check with Torque Pro if you can get a reading.
On my 05 Chevy truck, I could not pick it up with the mini ELM327, I had to use a full size OBD reader.
I'll check on my 02Z to see if I can get the data once it is ready to fire up!
Old 05-20-2014, 10:32 AM
RDnomorecobra
Right, I was thinking of trying this one
Amazon Amazon
but don't want to drop the coinage unless I know it will work. Guess I could try and return it if not ...
Old 05-21-2014, 02:36 PM
crease-guard
crease-guard's Avatar
Oil temp is not available via OBDII. I've tried, tried multiple OBD readers. It's just not sent out on the serial line.
Old 05-21-2014, 02:57 PM
LateBreak
LateBreak's Avatar
Isn't it communicated to the IPC over the Serial Bus??
Old 05-21-2014, 03:38 PM
Sox-Fan
Sox-Fan's Avatar
Is it not sent or do we just not know the PID?
Old 05-21-2014, 04:55 PM
RDnomorecobra
Not sure it helps but according to http://en.wikipedia.org/wiki/OBD-II_PIDs ...
hex 5C, 1 byte returned, Engine oil temperature, from: -40, to: 210, unit: °C, formula: A - 40
Old 05-21-2014, 08:48 PM
Olitho
Olitho's Avatar
My Racekeeper does not return oil temp either. I wish it did.
Old 05-21-2014, 10:17 PM
Scooter70
Scooter70's Avatar
I can't see the PID with Torque Pro or HPTuners. A tuning-pro friend is going to bring his EFILive cable to work tomorrow to see if that will read the sensor.
Old 05-21-2014, 10:43 PM
lefrog
lefrog's Avatar
I can see the PIDs with Torque Pro but the values always return 0 for engine oil temp and engine oil pressure. I seem to have some values coming in for trans oil temp but I haven't been driving the car to see if it's reliable or not.
The coolant temp works though, so at least this one can be captured.
Old 05-22-2014, 09:14 AM
Sox-Fan
Sox-Fan's Avatar
trans temp works on my Aeroforce gauges. I'd also like to find dif temp, but I'm not sure it's there. I haven't even looked to see if there is a sender
Old 05-22-2014, 09:16 AM
Sox-Fan
Sox-Fan's Avatar
Oh, and a followup to my question of whether or not the PID is known, I should clarify that what I meant was - what are the chances that it is on a different PID, and not the SAE listed one? GM has done that before.......
Old 06-04-2014, 06:28 PM
RDnomorecobra
how about oil pressure. anyone picking that up via OBD?
Old 06-04-2014, 10:46 PM
Sox-Fan
Sox-Fan's Avatar
Yup. My Aeroforce Interceptor has it.
Old 06-05-2014, 01:40 AM
blkbrd69
blkbrd69's Avatar
EFI live will pick up OBD oil pressure on the C6, don't know about a C5.
I data log every session.
Old 06-05-2014, 07:10 AM
RDnomorecobra
Originally Posted by sox-fan
yup. My aeroforce interceptor has it.
c5?
To oil temp via OBDII - '03 c5z06
Old 06-05-2014, 09:16 AM
Sox-Fan
Sox-Fan's Avatar
Yes, C5
Old 06-05-2014, 10:38 AM
Mrjre42
Mrjre42's Avatar
All the info I've found is that GM is not using the SAE listed PID for oil temp on c5 z06.
Old 06-18-2014, 09:22 AM
RDnomorecobra
scooter70, any update?
Quick Reply: oil temp via OBDII - '03 c5z06
