Need to re-build PFADT coilovers?
Old 04-22-2014, 09:54 PM
383's Avatar
Default Need to re-build PFADT coilovers?
I was apprehensive to buy a used set of feather-lights because if they needed service Id be screwed but I found this place that can re-build PFADT's coilovers even though they're doneski.
http://www.anzeengineering.com/servi...hlins-service/
Old 04-22-2014, 10:11 PM
C5ZEE06
C5ZEE06's Avatar
Looks like a viable option for maintenance service of the double ahustables only...for the time being.
Old 04-23-2014, 06:36 PM
383's Avatar
Are the singles that different from the doubles that they wouldn't touch them?
I suppose I should ask them
Old 04-23-2014, 06:52 PM
RX-Ben
RX-Ben's Avatar
Yes, the singles are completely different. The doubles that are Ohlins-based use the LM-J damper (and remote reservoir) which is a very common circle track shock.
Old 04-25-2014, 09:00 AM
el es tu
el es tu's Avatar
anze is working on tooling to do the singles as well
To Need to re-build PFADT coilovers?
Quick Reply: Need to re-build PFADT coilovers?
