Please Help With R-Comp Tires for C7
Former Vendor
Here is our shop C7 on C5Z06 10.5" on all four corners, running Hoosier R6 315 30 18. No scrubbing issues and car performs quite well on the smaller wheel diameter.
Gasoline Addict
C7
have just three races down with the C7
Hankook slick
Front 280 650 18
Rear 280 660 18
It worked wonderfully.
Incidentally, the C7 is awesome and very very fast.
Some C6 Z06 remained behind me ...
Cölestin
Hankook slick
Front 280 650 18
Rear 280 660 18
Cölestin
Gasoline Addict
Originally Posted by Von Zoom
I have a 2010 Z06 and run Toyo 888s Front 315/30/18, Rear 335/30/18, mounted on CCW rims 11 on the front, 13 on the rear. Hoosier I run 315/30/18 and 345/35/18, mounted on the same rims. Both work well.
vz
vz
I took a look at the CCW rims to see if they have a stamped number which would provide the info, but no numbers are coded on the rims. On my Renal rims that I ran on the BMWs had that info stamped on the inside of the rims. Sorry, still do not know the info you seek.
vz
vz
You might want to contact Finspeed and see what they use. I ordered their 18" "Z06 setup", literally what I told them, which is designed to run 315/345 w/o rubbing. I think the fronts are 18x11 and the rears are 18x13 but I'm not sure what offset they use.
