Tire Pressure System on and off the track?
Life Starts at 120 mph
NCM Lifetime Member
Hey Gang, like most offen when I have a question I come here first. Two sets of wheels, one with and one without TPMS. I want to track the set without the TPMS.
Car: 2010 GS, M6
Q. Does anyone know of any issue with switch wheels "regulary"?
I'll check the owner's manual for turning on and off the TPMS, unless there is some one who can offer advice, reccomendations or had experiences along this line.
Thanks Y'all
Boxcar
Car: 2010 GS, M6
Thanks Y'all
Boxcar
You have a few options.
Easiest (to me) is to have two sets of TPMS, one in each set of rims/tires. You can also get LG's track box to eliminate TPMS, or you can do the seal 4 tpms's in a canister and mount canister in car.
I use the first option, two sets of sensors . I change rims tires almost every weekend. No issues (other than a bad TPMS trigger tool in the beginning, and a dead TPMS sensor once)
Hope that helps
Hope that helps
NCM Lifetime Member
Hope that helps
Hope that helps
I don't have them mounted yet, so I'd better get a set ordered. I think that is the best solution so that I don't mess with the OB Systems. Any recommendation where to order from?
T/M
I had mine cloned, so both my track wheels and my street wheels have the same sensor IDs, 2 track days in everything is fine.
http://forums.corvetteforum.com/whee...-the-tpms.html
Hope that helps
Hope that helps
I used the cloning, so now I can swap wheels without anything else. I bought a cloning kit from Amazon 4 sensors and the programmer. It was quick and easy I get to keep my eye on tire pressure when I am on the track and no worries when I switch wheels
A third option is when you always have a 2010 or later C6 street car nearby, their sensors will also transmit to your car. Learned that when the C7 was being introduced from a factor engineer.
When vehicle has 0 or 4 TMP's are present you can turn stability control off....However if you have 0 present and are within 50-150 feet of another vehicle with TMP's ..you car will pick up a TMP signal and then the vehicle goes back into stability control mode.
That was new to everyone present at the meeting by the way.
And if you find a good reset tool, let us know what it is. The one I have works intermittently @ best. End up taking it to the dealer 1/2 the time.
http://www.ebay.com/itm/K-Tool-KTI-71990-Tire-Inflation-Positioning-Sensor-Tool-Auto-Diagnostic-with-CD-/390783678794?hash=item5afc85b94a&item=390783678794&vxp=mtr
Had two cheaper tools before, and this one is soo cheap but works great for me, and I swap tires almost weekly...
K Tool KTI 71990 Tire Inflation Positioning Sensor Tool Auto Diagnostic with CD | eBay
What year is your car?
EVERYBODY that doesn't have a TPMS tool should get the $20 Cub Pro 101 tool that Tire Rack has on clearance right now. It's a nice little tool with a screen that shows the sensor's ID#, the tire pressure, and for a 2010-2013 it displays the temperature in the tire:
The software in the tool only includes up through the 2009 model year vehicles.
However, the 2010-2013 C6 uses a sensor that has been used in a bunch of other GM vehicles prior to 2009, one of which is the HHR.
That's why it says HHR at the top of the screen in the picture above - I selected HHR in order to do a diagnostic check on a 2012 GS sensor.
The tool is so cheap at their clearance price that it's just too good of a deal to pass up if you don't have a TPMS tool.
I believe it will also clone sensors.
Bob
The software in the tool only includes up through the 2009 model year vehicles. However, the 2010-2013 C6 uses a sensor that has been used in a bunch of other GM vehicles prior to 2009, one of which is the HHR. That's why it says HHR at the top of the screen in the picture above - I selected HHR in order to do a diagnostic check on a 2012 GS sensor. The tool is so cheap at their clearance price that it's just too good of a deal to pass up if you don't have a TPMS tool.
Bob
Will remember to use the rubber hammer tip.
Ordered the CUB PRO this morning. $30 beans w/ S&H beats the c-note my current one cost.
Terry
NCM Lifetime Member
Wow...great conversation....
I decided to get 4 new TPMS and have them cloned to the ones on the car. My friend in the tire business sold them to me for $45 each vs $60+ at Autozone and others.
Now to look into the TPMS Tool. I love new tools. Can't have to many tools.....ever!
So now I have GS rims with TMPS and Michelin Pilot Sport Cup Tires, and soon to have Z06 rims with TPMS and Michelin Pilot Sport ZR tires on them.
This is why the forum is so excellent, just sit down ask a question and read other threads. If you don't learn something....your
Thanks for all the great information.
NCM Lifetime Member
See soon at the Glen my friend
