Is Anyone Tracking Their C7 Corvette?
If so, what kind of mods and safety equipment are you running?
I'm an experienced HPDE driver (but not in a Corvette) and I'm interested in some weekend
track events with my Z51 C7.
Some things that come to mind are, harnesses & harness bar, R-Comp Tires & sizes, wheels,
brakes & pads, etc.
Would appreciate hearing what you guys are using.
Thank you.
brakes & pads, etc.
Thank you.
The C7 Z51 looks very capable in stock form. If I had one I'd get some spare wheels with a sticky street tire, a harness bar and harnesses, and some upgraded pads while ensuring there is good cooling to the front rotors... that's it.
brakes & pads, etc.
Thank you.
brakes & pads, etc.
Thank you.
And then there is Reese's car:
Supporting Vendor
We have trackedours several times and have a pretty complete list of what needs to be done..
Available:
Harness Bars
Tow Hooks
Penske Shocks
Alignment and ride height settings
Wheel and tire recommendations.
Call Joe at Phoenix Performance if you want an update on what is avaolable.
610-482-0141 jfaphoenix32@aol.com
Available:
Harness Bars
Tow Hooks
Penske Shocks
I have heard again and again that Phoenix Performance is the place to prepare any car for track use and they are the real Corvette race shop. Joe and his crew have been very helpful to me and my fellow racers. I suggest a call to Joe before you do anything to your car.
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
We have been doing a number of events on our C7 over the past couple months testing our new suspension parts and packages for customers.
Stay tuned....
Stay tuned....
That's great.
Can anyone make suggestions for harnesses & harness bar, R-Comp Tires & sizes, wheels,
brakes & pads, etc. for tracking the car?
Experienced drivers , please.
The preferred setup for a C5 is four 18x10.5" C5 Z06 rear wheels. This is actually what MTI was using on their black C7 for awhile. Toyo R888s are a great sticky street tire. I'd get 295s square.
Unlike its predecessors the C7 seats are fine. At some point you may want to add a harness & bar but not necessary for starting out. I am not sure who makes a bar for the C7 but there are likely to be choices. The stock tires and wheels are also fine until you are ready to move to R comps, If so an 18" f/r set-up is best. LG carries a Cobalt pad for the stock LS7 brakes - an excellent choice. I would check with Anthony at LG on those (change the brake fluid) and wheels when you are ready.
I've run R888 tires and would not recommend them for the street, particularly in the wet. (I actually prefer the old Toyo RA1's over the R888's)
This season will be my first time out on the track in a Vette. Would love to hear some feedback on brake pad compounds, aftermarket wheel & tire sizes and if anyone knows of harness bars that still maintain the stock 3-point belts.
Thanks.
PS- Clear bra being installed next week.
Supporting Vendor
St. Jude Donor '11,'13
Depending on the club, upper run group drivers are required to have safety equipment in the car. I've run with PCA, BMW and NASA events and have instructed with all 3. As the driving level increases, the harness belts are almost mandatory so you're not holding on to the steering wheel in the corners.
Thanks.
Thanks.
I will be happy to discuss pad compounds with you. Carbotech has several options. What tires will you be using on track?
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Supporting Vendor
We have been running our C7 Z51 and have tow hooks, shocks, harness bars and suspension setups available.
Call me direct if you would like to discuss..
Joe 610-482-0141
Joe 610-482-0141
Former Vendor
The factory brakes do work better than the prior generation of cars, but they are going to need upgraded if you are going to get serious with this car and run it on slicks. It is still very much a OEM brake setup, and can not take a radical car with a fast driver at the wheel. For those doing HPDE events, switch it out to Motul fluids and rock a set of Cobalt XR1's front and rear and it will do some pretty amazing things on track. Remember to say your a forum member as the Cobalts are on sale right now to forum members!
VetteWorks and Phoenix both have get solutions for tow hooks, and harness bars....both of which we sell.
Joe and Anthony,
Are either of you running 18" wheels? If so, what width are the wheels, and what size tires are you running?
Thanks for any info.
Supporting Vendor
Hoosier A's or R's...
!8 inch wheels all around.. 10'sup fronts 11's to 13's in rear. But rear spacing is tricky so you need to do some spacin and fittin...
The stock Michelin tires are quite good...
