A Smörgåsbord of new AP Racing Big Brake Kits now launching...for C5, C6, and C7!
Supporting Vendor
From our website regarding brake pad shapes:
Pad Shape for Six Piston Front AP Racing CP5060 Caliper
The pad shape our CP5060 caliper uses was created by AP Racing many years ago, and is used by a wide range of racing calipers today. It’s available in just about every popular racing compound on the market. That means you’ll never end up in a pinch without pads. The available pad compounds that Essex sells for the CP5060 caliper can be found below. Please keep in mind that there are many other compounds available on the market from other manufacturers. The list below is only what Essex sells. When purchasing this brake system, you have the option of buying one set of any of the pads in the list below at 50% off of the retail price. Underneath each manufacturer below, the pad compounds are listed from most aggressive to least aggressive.
CL Brakes= RC8, RC6, RC6E, RC5+
Ferodo Racing= DSUNO, DS1.11, DS3000, DS2500
Hawk Performance= DTC-70, DTC-60, HPS, Performance Ceramic
Note on using brake pads different from those listed above
Again, please keep in mind that the above is not an exhaustive list, and that there are many other pad compounds available in this shape from other manufacturers. Please note however, that the pad shape we use in our caliper is available in a variety of radial depths (heights), and that Essex recommends the 54mm radial depth version. Another common radial depth in this pad shape is 51mm (StopTech for example, uses this size in their ST-60 six piston caliper). The 51mm depth pads will fit into our caliper, but you will be leaving an unswept 'ring' around the disc near the attachment points to the hat (the pad will not hang as low in the caliper). Leaving a portion of the disc face unswept can create a temperature differential across the face of the disc, and doing so could lead to premature disc cracking.
Here's a drawing of the pad:
152.1 x 54 x18 mm
Cross Reference
Since we do not sell these brands, Essex cannot guarantee the fitment of these pads in the AP Racing CP5060 caliper. Based on our research however, we believe that these are the appropriate cross references. You should verify with either the manufacturer or your installer prior to purchasing any of them.
ALCON PNF4489X532.4
AP RACING CP3894D54
Brembo= B51
Carbotech= CT5555
EBC= (DP2006, DP3006C, DP4006)
Endless= RCP086 (D52)
HAWK HB109 0,71
Pagid= U1903
PFC 7790.XX.18
Porterfield= AP7790
Project Mu= F1090 (D52.5)
Pad Shape For Four Piston Rear AP Racing CP5040 Caliper
The pad shape our CP5040 caliper is used by a wide range of racing calipers today in a variety of popular racing compounds. That means you’ll never end up in a pinch without pads. The available pad compounds that Essex sells for the CP5040 caliper can be found below. Please keep in mind that there are many other compounds available on the market from other manufacturers. When purchasing this brake system, you have the option of buying one set of any of the pads in the list below at 50% off of the retail price. Underneath each manufacturer below, the pad compounds are listed from most aggressive to least aggressive.
Ferodo Racing= DS1.11, DS3000, DS2500
Hawk- Hawk is building some pads to our exact specs as I write this. They will be available in DTC-70, DTC-60, and HPS
Please keep in mind that the above is not an exhaustive list, and that there are many other pad compounds available in this shape from other manufacturers. Please note however, that the pad shape we use in our caliper is available in a variety of radial depths (heights) and thicknesses, and that Essex recommends the 42mm radial depth version, in a 16-17mm thickness.
132.4 x42 x16.7 mm
Cross Reference
Since we do not sell these brands, Essex cannot guarantee the fitment of these pads in the AP Racing CP5040 caliper. Based on our research however, we believe that these are the appropriate cross references. You should verify with either the manufacturer or your installer prior to purchasing any of them.
ALCON PNF0084X276.4
AP RACING CP3215D42
PAGID 2126
PFC 7768.XX.16
152.1 x 54 x18 mm
Cross Reference
ALCON PNF4489X532.4
AP RACING CP3894D54
Brembo= B51
Carbotech= CT5555
HAWK HB109 0,71
Pagid= U1903
PFC 7790.XX.18
Porterfield= AP7790
132.4 x42 x16.7 mm
Cross Reference
ALCON PNF0084X276.4
AP RACING CP3215D42
PAGID 2126
PFC 7768.XX.16
Supporting Vendor
Hi Guys,
We've had a number of customers ask us recently if they can run an OEM-Style C6 Z06 disc with our front Endurance six piston kit, since they have the same overall dimensions as the AP Racing discs in our kit (355x32mm). The answer is yes, it will work with a slight modification. That said, we always recommend using our complete system with the AP Racing discs that are included. These parts are designed to work together for superior results. We do recognize however, that some customers may have been running OEM-style discs for a number of years and could have a considerable quantity of spares on hand, might need a spare disc in a pinch at the track, etc. Please note however, OEM replacement discs from various manufacturers tend to vary in size and tolerance, and Essex cannot guarantee the fitment or performance of any disc other than the ones included with our kit. The data below is for informational purposes only!
The offsets on the discs in our system are slightly different than stock, so to fit an OEM-style disc with our calipers, you would need to install a very small shim (0.032" or 0.81mm) between the caliper bracket and the upright, moving the caliper out towards the wheel spokes. One shim is used around each caliper bracket mounting bolt for a total of 4 on the front axle. You can see one of the shims circled red in the images below. The shim goes between the bracket and the suspension upright, and this does not require the use of a longer bolt. Adding the shims centers the OEM-style disc within the cailper. These shims can be found here. If you decide to do this, please note that wheel fitment will change, and allow for an extra 1 mm of clearance when using our wheel fitment template).
Also note that we will not sell our big brake kits without discs, so please don't ask! Again, we recommend our complete system including the AP Racing discs for maximum performance and reliability.
Below is the OEM style disc installed without a shim. You can see that the disc is not completely centered in the caliper:
In this pic you can see a shim installed, circled in red.
With the small shim installed, the disc is centered in the caliper.
Here is the disc installed:
Supporting Vendor
Hi Guys...I don't think I've posted any pics of our four wheel kit installed yet...so here it is!
Our kit shaves 34 lbs. of unsprung weight off of a C6 Z06!!! That's 18 lbs. off the front of the car, and 16 lbs. off the rear.
Supporting Vendor
Our front C7 Stingray kits are now shipping!!!
Essex Designed AP Racing Competition Big Brake Kit for C7 Stingray
While the C7 Base and Z51 brakes are more advanced vs. the C5 & C6, there is still a lot of room for improvement. Based on everything we’ve learned during development, we believe our system offers our customers the following advantages over the front OEM C7 Stingray brake systems:
Supporting Vendor
Front AP Racing Factory Road & Track Big Brake Kits for the C5 and C6 are now available for purchase!
AP Racing's Factory Big Brake kits are the finest systems available for enthusiasts wanting to run their car on both the street and track. These systems are fully designed, manufactured, and assembled by AP Racing in England, and imported to the USA by Essex. While some of our more hardcore customers favor our more track-focused Essex Designed AP Racing Competition Brake Kits, others are looking for something with more street-friendly features such as dust boots, painted calipers, etc. For these customers, the Factory Kits are the perfect fit. They bridge the gap between daily driving and weekend track thrashing.
We have these systems available for all trims levels of C5 (1997-2004) and C6 (2005-2013) Corvettes.
Downloadable wheel fitment template
These new Factory BBK's are in stock in both red and black, and are shipping today.
- Red or Black calipers available
- Saves nearly 5 lbs. of unsprung weight from each front corner of a C6 Z06
Brake
The large 380 Alcon and AP brake is really very good.
However, strain With hard I'm a little disappointed with the brake disc.
Since we switched to Brembo discs ... live much longer.
Also, all GT3 team of Callaway have changed from Alcon on Brembo
Cölestin
Cölestin
Supporting Vendor
Below is the first in-car footage of our front Competition six piston kit in action.
This was Oli T taking the first podium on this kit out at Inde Motorsports Park in Arizona a few weeks ago. This was an SCCA Majors race, in the GT2 class.
Skip to the tail end to see him reel in a 911. He even bumps the Porsche for a little drama...oops. Congrats Oli!
https://www.youtube.com/watch?v=NLw7...w&noredirect=1
Ha! Yes, Jeff I did reel them both in very well. It is evident that the vaunted Porsche braking had absolutely zero advantage on my AP caliper and rotor equipped Corvette. In fact, if there is one area where my car was performing the best against the Porsche it was under braking. The best part of the whole video is the last lap at minute 36 or so. Shortly after that mark, three turns before the end, I bump him lightly.
Spencer, the driver, was hopping mad. Watch the closing seconds of the video and you will se his door open twice before he even stops. He could not wait to come and yell at me. I cut that part out of the video as it is choice. The stewards stepped in to calm him down. I thought his reaction was extreme as it was called in by the corner workers as a racing incident and I did not spin him and there was no change of position.
#37
Supporting Vendor
All Current Essex/AP Racing BBK owners please read below
We recently sent out a survey to those who bought their Sprint or Endurance kit directly from Essex. Now we're looking for those who bought their kit from a different shop. I have a survey that I'd like you to complete. It will help us continually improve our products and offer more of what our customers want. In exchange for filling out the survey we will offer you a very nice gift at no charge...and yes, it's something you will want and can use. Please shoot me an email and I'll send you the survey. Thank you very much for your help!
#38
Supporting Vendor
Hi Guys...We're doing a $500 off Tax Day sale on our AP Racing Factory BBK's. Again, this is only on the Factory BBK's for the C5 and C6, which are the road & track product. The discount does not apply to our Competition Kits.
Front C5 Black
Front C5 Red
Front C6 Black
Front C6 Red
These have a 362mm disc and are about as big as you can cram behind an OEM C6 Z06 18" wheel. They come with everything you need...even brake fluid and pads. Despite being huge, they don't have any weight penalty on a C5 or base C6, and shave nearly 10 lbs. off the front end of a C6 Z06! Get 'em while they're hot.
Front C5 Black
Front C5 Red
Front C6 Black
Front C6 Red
#40
Supporting Vendor
Here are a couple more great reviews of our Essex Designed Competition Big Brake Kits for Corvettes....and some pics of them on the cars!
