I don't see why it wouldnt work, my bracket simulates the knuckle on the Vette.
Here is what mine looks like.
Here is the actual bracket I run
Having spent most of my time since the 20th moving into a new house I just got back to this thread. I misunderstood what you were calling a bracket. I thought you were using the base C6/C5 caliper mounting bracket that bolts to the knuckle. This is quite a bit different. Hopefully, you have everything worked out with KNS by now. The only thing I think you need to be worried about is tolerance stack up when bolting so many parts together.
Lower prices on the kit with SS piston calipers - and we'll add the thermlock caliper option.
We have a few sets of calipers here ready to go.
Thanks for patience.
And I agree w/ Bill. The placement should be correct as long as parts don't hit each other. The bosses on his AL bracket look pretty big compared to the knuckle of the car.
